Question about Honeywell Programmable Thermostat Heater
Honeywell Chronotherm IV Plus requires frequent resetting.
We recently moved to this house. Since we began using the heat, the programmable thermostats have to be reset almost daily. (There are three thermostats -all have to be reset often but one has to be reset almost daily.) We thought it might be that the batteries needed to be replaced, but there are no batteries.
I am not sure which model we have, but the owner's guide is for the CT3500 and CT3595.
Any suggestions why this is occurring? I need to get this resolved as my wife works from home.
Thanks,
Tim
  • 2 more comments
  • jandn911 Feb 02, 2009
    having similar problems.. have you found a resolution. We too just recently moved into our house, so have no history or manual.
  • omsms Mar 04, 2009
    I bought this thing with a new heating ac system some 18 months ago. What a piece of ****. It is tooo smart and tries to do too much. It measures the wall temperature and matches that against the air temperature to get a more "reliable" reading. What a joke that is, first, if its an outside wall you are screwed, second, it will run heat or ac until the WALL reaches the desired temperature. Thats ok if you never setback but if the wall gets cold during the night, the next morning, heat will run like crazy until the stupid wall warms up.
    I have seen the dumb thing calling for heat even when the displayed temperature is three degrees above the setpoint with no end in sight.
    The pre heat function was so bad, I finally turned that off. It started the heat 5 hours before I wanted to get up, baking me in my bed in the process.
    Tech support is some Indian company where they barely speak English, email replies are canned and worthless.
    Forget this piece of **** and just get a regular setback thermostat. All the bells and whistles are just gimmicks that don't work.
    Everybody I know regrets buying or having one of these things.
    Honeywell gets so many CS calls on this thing they have canned answers like "its your furnace".
    My furnace?? How would my furnace be affecting the thermostat?
    Too bad honeywell has gone the route of all the crappy companies. They used to be pretty awesome.
  • eimpala May 11, 2010
    Can you remove the thermostats and get the model numbers on the back of the stat? Do you have a zoning system, or three separate systems?
  • 308 Answers
Check to see if you have wires going to a C/C1 terminal. The older chronotherms used a transformer to supply 24 volts to power the clock. If in fact you do have these terminals, then I would suggest checking the output voltage on the transformer, (secondary (24v)side) to ensure it isn't close to dead. Hope this helps
Posted on Jul 20, 2009
shastalaker7
  • 1515 Answers
SOURCE: my honeywell programmable thermostat chronotherm
Hi, if this thermostat has batteries, try and replacing them. It sounds to me as though the circuitry in the sub-base has a problem keeping the stat programmed. Shutting down with in 30 seconds and back on only to shut off again tells me that the sensor that is a part of the circuitry on the sub-base that senses the rooms temperature, has failed and it cycles on and off. If it does have batteries, change them to see if this solves this problem. If no batteries, shut the power off to the a/c and remove the cover to the stat. If this does not expose the control wires, you will have the stat sub-base to remove. It will have several small screws that will need to be loosened to get to wiring. If your system has a gas furnace or electric heat and not a heat-pump, you will have terminals marked like this. RH, RC, with a jumper wire connecting the 2, W white for heat control, G, green for fan control, and Y, yellow or they may have used blue for cooling control. You can pick up a new programmable thermostat at Home Depot, Lowe's hardware for this for around $30. It will come with the Red jumper already wired in and this is where you connect your existing red to either one, but leave this jumper on. This will solve your problem. If you have no gas furnace and it is a heat-pump, it will have many more wires and terminals such as this, R, W-1, W, E, O, B, Y, C. Draw your self a diagram on the wire terminals and colors of all wires and what terminals they are connected to so you get it right and take this along to match it with the correct heat-pump thermostat. Honeywell has good dependable stats, so try and stay with them. If the price for one is off the wall, go with a White Rodgers, Hunter, Carrier, and just look them over good. Read to see if they have batteries for the display and if they are included with the stat. This will solve this problem. Please don't forget to rate me on this as I know you will be kind. I will be checking in to see how you are coming along and if you need more help as I will be here.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Aug 30, 2010
  • 83 Answers
SOURCE: honeywell chronotherm IV Plus thermostat
There are no batteries on an 8600-8601-8602 series
Posted on Sep 19, 2008
  • 10 Answers
SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
  • 588 Answers
SOURCE: how do I program my honeywell chronotherm IV Plus
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Feb 28, 2010
  • 588 Answers
SOURCE: i have a honeywell chronotherm iv plus thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Posted on May 10, 2010
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
We have a braemar chronotherm IV plus It turns the heating on and off after aproximatly 5 minutes we have replaced the fan and had a plumber here several times each time he replaces a part now he is...
What type of heat, electric, gas or heat pump, did anyone replace the thermostat recently? Did he replace the capacitor when he replaced the motor?
It sounds like either an airflow problem or a fan or limit switch, possibly the thermostat.
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 11, 2009 | Honeywell Programmable Thermostat Heater
The fan on my central heating system keeps running
IN MOST PROGRAMMABLE STATS THERE IS A FACTORY DEFAULT PROGRAM.IT COULD BE
RUNNING IN THAT MODE.FIRST,CHANGE THE BATTERIES IN THE STAT.ALSO,THEY HAVE A
RESET BUTTON ON THE CIRCUIT BOARD.TRY THAT.AND,BY THE WAY,YOU ARE NOT SAVING
ANY MONEY BY DOING A TEMP SETBACK.THE HEAT SYSTEM WILL USE JUST AS MUCH
FUEL EVERYDAY TO RECOVER THE LOST HEAT DURING THE SETBACK PERIOD.ALSO,THE STAT COULD JUST BE BAD.
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
Feb 17, 2008 | Heating & Cooling
Heating & Cooling Logo
4,541 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
