Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
WD5000 My Book 500 GB -- I/O error cannot access
My computer recognizes the external drive, but when I click on the drive in My Computer (running right now with Windows XP) I eventually get
not accessible and I/O error.
The light flashes and I hear a fan.
The My Book was dropped which probably caused the problem.
Thanks.
  • appinaveen Mar 12, 2009
    h have a problem my wd portable hd 250 is not working, when i connect to the computer it shows that drive is not acessible i/o error. so please help me to fix the problem
I had exactly the same problem with a WD 500gb External HD MyBook Edition USB , eventually opened up the case removed the 500gb Caviar disk put it in an external HD Case (AC Ryan's AluBox)
and still had I/O error !!! i had serious music projects and stuff i didnt want to lose , after lots of research and looking around this program SAVED MY LIFE AND ALL OF THE STUFF IN THE HARD DISK !!!!
Ontrack EasyRecovery Professional v6.20 retail first i run the simple in-depth diagnostics then i used the EasyRecovery DataRecovery option and after about an hour of scanning started copy-pasting all my files onto another disk ! this app saved my life a special thanks to its programmers ! im John from Greece , hope this helps bro!
Posted on Nov 18, 2009
External Drive not recognized
Is this a new drive which you have connected to the computer ?
Aug 15, 2008 | Western Digital My Book Essential Edition...
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
My WD ext hard drive will not be accessed by my computer
If the drive is new, you may need to format it. If you already have data on it, then DO NOT format it.
If it is new, you'll right click on the drive icon and click format. After the drive is formatted, you'll be able to open the folder for the drive.
Feb 01, 2010 | Western Digital 500GB My Book Pro-External...
My computer now recognizes the drive but
See: http://www.fixya.com/support/t3770934-western_digital_hard_drive_isnt
Connect the external drive
Click Start
Right-mouse click on My Computer
Click Manage
Click Storage
Click Disk Management (Local)
Does it show the 500GB as "raw" or "unformatted" space?
If so, then "create a partition".
Jan 01, 2010 | Western Digital My Book Essential Edition...
WD5000- I can't save files anymore to the disk drive. The file on the external drives are fine and I can access them or copy them. When I start copying files to the external drive I get a error that the...
A few things to check
1. ensure the drive is connected directly to the computer and not via a HUB
2. ensure you use the original cable that came with it (not one that looks the same)
3. remove as many other usb components as possible
4.check the power supply for the external drive if it has one
5. shut down and restart the computer
At this point you should be able to see and move files around.
If this is not the case and the drive is no longer under warranty you could try the following
remove the drive from its enclosure and mount it in a computer that has a suitable interface SATA or IDE. if you can now use the drive normally then the enclosure is at fault. If the drive cannot be used normally then the drive is at fault. If its the drive then it is either dying or dead.
Also you should ensure your antivirus is totally up to date and that you also have ANTISPYWARE software installed too and that your computer is clean from any nasty stuff.
If this information was useful please click
Aug 17, 2009 | Western Digital 500GB My Book World...
Computer does not recognize My Book
Right click on my computer.then left click (LC) on manage. go to disk management. if you dont see your drive try removing it and plugging it back in. if it does see it RC and LC on initiallize drive. you should hear a da dum from windows when you plug in a new piece of hardware. or whenit initializesthe drive. if not you have an internal problem with the drive. the drive may be fine but some of the electronic components can fail. you can try using a different external harddrive enclosure @ 15- 30 $. Does the drive light up. fi you get it up runnig you may want to consider bacing up the data you ext. drive may be close to failing.
Jun 23, 2009 | Western Digital My Book Essential Edition...
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
May 06, 2009 | Western Digital My Book Essential Edition...
Western digital my book 500 gb external hard drive
try to right click on "My Computer"->Manage-> Disk Mng.
Then try to see if you can recognize you this disk.
maybe you just need to change the letter or format it.
Apr 05, 2008 | Western Digital My Book Essential Edition...
XP doesn't recognize my external 500 GB WD My book essential edition hard drive
Dear karroll.
Im having same as you're problem. but there is solution that might help you, but didnt work for me for some reason..
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
Best regards
-evo
Nov 27, 2007 | Western Digital My Book Essential Edition...
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
1,669 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
