D-Link DSL-500T Router Password Recovery
Hello.
Is it possible to recieve login and password form this router somehow?
Thanks in advance.
While the router is starting up press and hold the reset button (probabaly u can find this in a tiny hole of your router). after light flashes leave it. restart the router. the routher will be in factory settings mode. if you know the defoult password u can login.
Posted on Dec 22, 2008
Forgot password D-Link DSL-504 ADSL Router 4 Port or mack resetting
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 31, 2010 | D-Link DSL-504T Router
Hi how do i log in to my d-link wireless router so ican change password and set up wireless cont
OK if you DO NOT know you logon & password, you will have to reset the router, remove from the power and locate the button inside a small hole at rear, press this in for a few seconds, and now your router is set to default settings and the login and password is admin, both times. You login by connecting up via an Ethernet cable and use a browser and enter the default address of the router into the address bar, 192.168. ..... and press enter. enter the login and password, admin admin Then it is a simple matter of following the instructions to set up your connection. I have given you a link for your user setup manual below get it and it shows you exactly how.
You will need your ISP Provider's logon and password.
www.cstuff.co.nz/.../D-Link/DSL-G604T%20GenII%20Installation%20Guide.pdf
All in the downloadable manual above.
Aug 06, 2010 | D-Link DSL-G604T Wireless Router
Netgear wireless-N 300 router directions
Direction for using and configure router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your query
Thanks for using Fixya
May 05, 2010 | NetGear WNR2000 Wireless Router
NETGEAR wirless router installation
You can use below steps to install router
ROUTER SETUP
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 address bar. press enter
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on lan ip setup under advanced.
6. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
8. Power off the dsl modem and the router after making the connections.
9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
11. Access the router (http://192.168.10.1).
12. Login to the router (Username = admin Password = Password).
13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
15. Click Apply.
16. Logout of the router.
17. Open up another browser window and try to access internet.
Please rate the service positively if issue resolved
Apr 04, 2010 | NetGear RangeMax WPN824 Wireless Router...
Pc has been wiped now i want to reconnect to wireless router
Hi
please follow steps to reconnect to wireless router
16. Click Apply.
please rate service positively
Mar 26, 2010 | NetGear WGR614 Wireless Router
Password recovery steps for lucent dsl max 20 dsl terminator
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and
www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
Mar 13, 2010 | Lucent DSL Terminator 100 Router
Forgot the password and user name how do i retrieve them
First Connect your router to computer with ehternet lan cable.
Then access it with following defaults link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
If you are not able to login with above then you need RESET router .
For that press RESET button it is in back side of router press it for 10 seconds.
Then follow above direction then you can see configuration of router.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
Forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Jun 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Router problems
Hi!
The default password is admin.
Please see this link for the default settings and password for your 3com router---
Default Password
Please rate this solution
Thanks
Rylee
Feb 14, 2009 | 3Com OfficeConnect Wireless Router
Router problem
Hello!
Here is a guide on how to setting up port forward on DSL 500T for uTorrent:
http://www.portforward.com/english/routers/port_forwarding/Dlink/DSL-500T/Utorrent.htm
If you can't reach the router as described in the link above, than you need to contact whoever provided you with this router. If the router was provided by your ISP (internet service provider) than contact them directly asking how to access your router.
Hope this helps!
Sep 23, 2008 | Computers & Internet
Computers & Internet Logo
903 people viewed this question
David Payne
David Payne
