Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Picture is hourglassed shaped
TV turns on fine, but the picture is black along both the right and left sides. Sometimes hour glassed shaped and sometimes aprox. 3 to 4 inches wide. Is there an adjustment that can be made? Need help please...
    Scholar:
  • 168 Answers
Your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Posted on Jan 15, 2007
THE PICTURE HOUR GLASSES IN SHAPE
Your symptom sounds like a damaged component in the pincushion circuit.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
I would recommend that you have a local service center diagnose the set for you and give you an estimate of the repair.
I have seen this type of repair run from $250.00 - $350.00.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 09, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Hourglass shaped red
I need to see a picture of the TV set. send a photo to techman32k@yahoo.com
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
