I HoneyWell Heat Pump Thermostat and would like to upgrade to a digital. Can I use a standard digital thermostat? or do i need a specific heat pump thermostat?
  • 182 Answers
Honeywell 8000 is a great digital thermostat that works very well with a heat pump
Posted on Nov 30, 2008
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
Hi, I have an air source heat pump that warm the water in my koi pond, it works really well but the only problem I have is the coolest I can set the water temp is 15 degrees. My question is would I be able...
Providing its a 24V controll circuit, any heat pump thermostat would do the trick. The real trick is finding one that goes down to 8 degrees. Make sure the range goes down that low, and that it's a heat pump thermostat. A lot of Honeywell thermostats work on both conventional, and heat pump systems. You'll have to read thru the installation instructions to program it from the default conventional setting, to a heat pump setting. The manuals are quite user friendly with pictures and everything! Good luck!
Apr 11, 2013 | Honeywell Programmable Thermostat Heater
Can a honeywell programmable thermostat #RTHL2410C be programmed for heating and air system with heat pump and heat strips
Heat Pump, yes. Heat strips, no. A heat pump system that uses electric back up heat needs at least a 2 heat/1cool thermostat. It will have the options you need for your system. Unfortunately, your Honeywell will not work. Sorry, hope this helps!
Nov 18, 2012 | Heating & Cooling
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Thermostat says ''Aux heat on'' and buzzes when we turn on heat
You most likely have a heat pump, the aux heat (usually electric) comes on anytime the room temperature is 4 degrees below the thermostat setting. Does the buzz go off when the aux heat lite goes out? If the aux heat does not shut off then the primary heater (heat pump) is not putting out enough heat to satisfy the thermostat. I need a little more info. Do you have a heat pump? Is it working?
Nov 19, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
