Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
ATA133 refusing to be accepted
I have FoxConn SIS 755 CHIPSET MOTHERBOARD containing a "SIS 5513 UDMA controller under Device Manager under the AtAPTI controllers, and a Samsung Hard Disk drive (HDD) model 1604n 160 gig max interal drive. By my understanding i HAVE a 80 pin conductor cable plugged correctly from my Primary IDE plug on the motheboard to the HDD...the cable reads 300v and some other specs on it. I compared that info to a "80 pin conductor cable" search at Newegg.com through the shopping link. I believe i have the correct cable..I have updated the mobo UDMA CONTROLLER driver to I204A which is a 5.30 mb unzipped file which i had to do a Google search to find..FoxConn support via the website is basically nonexistent. I was told the IDE version of the HDD, which i have, does not require drivers. My computer, when i set to use DMA TRANSFER ACCESS mode, it refuses to boot. it will only work on PIO MODE 4 which is the same thing as ATA100. POst test screen always says, no matter what i adjust in BIOS, "no 80 pin conductor cable connected" I have tried three different brands of the 80 pin cable...yet no results..pls help...chronofusion@bellsouth.net
  • dustin tyson Jan 16, 2007
    I did that..the bios auto reverted back to enabling DMA TRANSFER ACCESS AND DMA BURST MODE.. And after the post test it says "Boot Easy Success..." then it stays stuck there it won't load Windows XP Home. it's the DMA TRANSFER ACCESS that poses the problem still. it still says "no 80 pin conductor cable installed...also..do i have to have two physical hard drives to have a REGULAR SATA drive with it's 1.5 mb per sec performance or better performance? or cann i just have one SATA hard drive and it run the 1.5 mb/per sec performance and I can see it in Device manager\Primary IDE Adapter or Controller listed as SATA or ATA7?..or will i have to buy a MSI mobo for this stupid pc of mine to not say "no 80 pin conductor cable connected to drive 0"..lol..
    President:
  • 2,961 Answers
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Posted on Jan 15, 2007
  • andrew pester
    andrew pester Jan 17, 2007
    ok iv'e lost the plot a bit here, are you fitting a sata drive or an ata drive?.
    If you are fitting a sata you will need to install drivers to the mobo and when you are prompted just before you start to install Windows.
Foxconn motherboard 2006 p4
download here
http://www.foxconnsupport.com/download.aspx?models=en-us0000111&category=C000000001&brand=en-us0000001&Series=en-us0000001&chipset=en-us0000051&keywords=&sort=
Oct 02, 2012 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
VGA : SiS 315 Integrated Video Adapter [AsusTek] Chipset : SiS 650 + 85C503/5513/961 Mother board : ASUS P4S333-VM iam traying many vga driver but my sys not support any driver so can you help. my...
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 10, 2011 | ASUS P4S333VM (AP4SRRVM) Motherboard
I just install win7 on my computer then plug in the internet cable then i cant get no connection. i went to device manager it say driver needed call (ethernet controllor) agp8x motherboard driver ...
click start control panel admistrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
http://www.driverstt.com/downloadfile/50575/asus-p5p800-vm-realtek-rtl8100c-ethernet-driver-5-624-304-2005/
hope this helps
http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
Apr 24, 2011 | MSI 661FM-L, 601-6540G-010, Microstar P4...
I cant find drivers on integrated Videocard "Sis 330 Mirage IGP" in motherboard "Foxconn N15235". Help). PS:system cant recognize videocard.
here are the drivers
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001103
hope that helps let me know
Mar 19, 2011 | Foxconn 6627MA-RS2H Motherboard
When I download a program an click to install it a box pops up saying the download I am trying to install is not a valid Win32 application. This is a new problem. I have not had any problems downloading in...
This error message could be caused by a number of things. Generally it's because the program being downloaded is corrupt or didn't download completely. Have you tried a different browser to do the downloads? If it's a very large download you may encounter problems with losing packets. A download manager may help.
http://www.techspot.com/downloads/231-free-download-manager.html
Also, you may want to try doing a restore to system restore point to a date when you weren't having this issue. System Checkpoint dates (in bold) are usually very safe points to restore to. I would also recommend a virus scan and if you don't have this utility and are able to download and install it (yes I know that's your current problem, but you can download it to a flashdrive from a friend's comp and install it), I'd get Glarysoft Utilities and run the one-click maintenance which will fix any registry errors. It's free and is a great way to keep your machine running well.
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html
If any of this helps correct your problem I would appreciate a rating. People here seem to take the help and don't show any appreciation by taking the time to rate the help.
Jan 11, 2011 | Computers & Internet
Problem(s): No sound from CD/DVD player, webpages like YouTube, etc. On board sounds still work. Volume, Audio, and Voice tabs under Sounds and Audio Devices are grayed out (unselectable). I've tried...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
hope this helps
Dec 13, 2010 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Vga driver
I found the site to suggested to you.
Foxconn Site
Link
Direct Driver Download
Link >>> VGA Board Driver
Link >>> AGP Driver
Just Click and follow the link
Or you can download it from sis website, coz this motherboard uses the SiS 760GX motherboard chipset drivers, which you can download directly from SiS:
http://www.sis.com/download/
Jun 03, 2009 | Foxconn WinFast K7S741MG Motherboard for...
VGA PCI bus
This motherboard does not have the advertised chip set on it. Instead of the SIS 761GX and 900 lan, it has the SIS 740GX and 190 lan. I had exactly the same problem and I wasted three days searching for the solution. Either the board is mislabeled or Foxconn conned everyone with a lesser chipset. The correct drivers are readily available at http://www.sis.com/download/ .
Aug 28, 2008 | Foxconn 761GXK8MB-RS Motherboard
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
339 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
