Question about Sony KV-32S25 32" TV
Need to unplug for about 5 minutes before tv will power on
A while back my Sony KV-32S25 stopped powering on. Through some "accidental" testing I figured out I could unplug it for about 5-10 minutes, then plug it back in...and it will then work fine. Until I shut it off!!!
Then I have to go through the same process again. I also noticed if I leave it unplugged for too long, my little "trick" won't work. If the unplug time is too shot or too long it won't power on. About 5-15 minutes seems to be the range.
Any ideas???
  • Sony Master
  • 4,024 Answers
Its more likely to be bad capacitors on the power board but you will need to see first, it could also need reflowing on the main av board there is a large chip on there that some times can cause this problem when it starts to come lose from the board ( hot then cold temps) there are plenty of home remedies to do this, essayist is a halogen light and make something to support it around 1 to 2 cms above the chip making sure the board is flat, leave the power on the light for an hour or 2 then let it cool down. other way is with a heat gun but you need to be careful as the plastics can melt doing it this way you need to cover them so they don't get hot.,, but check capacitors and voltage first.
Posted on May 25, 2017
5 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Sony KV-32S40
When the horizontal output (2SC4927) is shorted it means one of 2 things is wrong - the horizontal drive transformer has cracked solder joints or the flyback transformer is shorted inside. If the solder joints on the horizontal drive transformer (the small grey transformer connected to the base of the horizontal output transistor) are cracked then the set will play for a little while and then the parts you just replaced will again be destroyed. ALWAYS resolder the driver transformer when replacing the parts you mentioned! When I replace the parts you mention and I do not see any obvious cracks on the driver transformer then I unsolder the B+ pin of the flyback (labeled 135, for 135 volts) and put a 60 to 100 watt lightbulb (drop-light) in series with the flyback. This means that the 135 volts B+ goes through the lightbulb and then into the flyback, so the lightbulb acts as a current limiter to protect the horizontal output. When you turn the set on the bulb should glow no more than about half bright and you should hear the high voltage come up, but you should not see a picture. If you turn the set on and the bulb glows as bright as if it was plugged into the wall then you can bet that flyback is shorted and must be replaced.
Posted on Jul 13, 2007
  • 1694 Answers
SOURCE: Sony KV-32S25 32"
Check Horiz. output transistor = shorted?
1)replace with first quality transistor
2)solder horiz driver circuitry
3)replace shorted converter transistors (2SC4834)
4)Replace open R607 .1 ohm 1/2 w.fusible (resistor ok)
   test.......T.
Posted on Oct 26, 2007
  • 4234 Answers
SOURCE: how can i change ntsc to pal / kv 32s25
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Dan
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: sony wega kv-34xbr800 doesn't turn on sometimes
You need to replace 2 ic part MCZ3001D located on the fron of the board on the left side
Posted on Sep 11, 2009
I have sony kv-32s25 powers on but no picture i do have sound and the stand by light is flashing and idea's
The key here is the standby light flashing. It should be flashing in a repeated count of flashes with a pause inbetween. Count the blinks and report that number here. This is a diagnostic code indicating the circuit that is having a problem. Armed with that info, we should be able to give you an idea of the problem and its solution.
Thanks,
Dan
Apr 28, 2010 | Sony KV-32S25 32" TV
My Sony 32" inch has power, but no picture. When it is on the Standy/Timer light just blinks.
May be its Timer ON/ Off function is ON. Bring it back to the normal mode. Reffer User manuel.
Sep 11, 2009 | Sony KV-32S25 32" TV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
How can i change ntsc to pal / kv 32s25
Dan
Mar 16, 2009 | Sony KV-32S25 32" TV
No power to my KV-32V15
Unplug the unit, wait at least 30 minutes before beginning work after unplugging. take the back case off, there are 10 screws I believe holding it on. Where the power cord goes into the unit, look on the circuit board and you'll see a fuse. Check the fuse, I'll bet it's bad. Replace with the exact same type. I have the same TV, had the same issue. I'm now enjoying it just as I once was. Good luck.
Remember to be VERY careful when inside a TV, there are power sources that are fatal.
Nov 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking
your picture tube is bad. rejuvenate may work ..
Apr 01, 2008 | Sony KV-32S25 32" TV
Sony KV-32S25 32"
   test.......T.
Oct 25, 2007 | Sony KV-32S25 32" TV
Sony KV-32S25 loss of picture and sound
The set might have loose conections in the horizontal drive circuit and other overheated places in the power supply,dont use the set like that or it wii die completly and it will be more expensive.Call a technician so he can resoldered all the bad and questionable solder conections.Be safe and let a proffessional do it.Good day.
Sep 13, 2006 | Sony KV-32S25 32" TV
Televison & Video Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
