Question about ION Audio Vinyl Recording Turntable
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
  • 33 Answers
Hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Posted on Jul 09, 2009
I get no sound when connected to CD connection
if there is no phono input,you need a pre amp to drive it.the record player puts out 5 mv from the cartridge.
a cd player is 800 mv to one volt output.
the turntable can not drive the cd input.
a phono pre amp also has a 60db gain from 20hz to 1khz to offset the -60 db curve when records are made to reduce the groove modulation.
without the bass attenuation,record grooves would have to swing 4" for bass notes.
google RIAA equalization curve for a description.
Sep 01, 2009 | Yamaha HTR-5830 Receiver
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
MAC Computer wont recognize Numark HDX when connected via USB.
Did you format your hard drives thru the menu on the deck? If not you may need to format the hard drives first and then plug them in. *NOTE DO NOT FORMAT DRIVES THRU YOUR COMPUTER* format the drives thru the decks in the utility menu.
Apr 29, 2009 | Numark HDX Turntable
USB Device Not Recognized
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Aug 28, 2008 | Crosley 0187SST Turntable
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Profile over the range microwave
It might be better to post this in the GE section, but I'll be happy to answer it here, too.
I would suspect a bad magnetron or high-voltage transformer, but it may be the turntable motor or an arcing stirrer.
If you can post back with the model number and a bit more detail on when and how it happens, we may be able to help you better.
Oct 23, 2007 | Microwave Ovens
ION Audio Vinyl Recording Turntable Logo
69 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
