Question about Philips 55PP9701 55" Rear Projection Television
Green Picture. My 55 inch philip has a green picture on every channel I tried to adjust the color but was not lucky. What could I do to adjust the green.
    Scholar:
  • 168 Answers
I suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Posted on Jan 16, 2007
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Apr 15, 2013 | Televison & Video
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
My plasma picture looks green
You are proberbly using RGB leads, wich is red green blue, each colour runs through each cable, have a look at your cables maybe one is loose, or damaged. check on both ends, but the cables MAY NOT be red green and blue, but the terminals that the plug into will be.
Jul 05, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Green tint screen
Took mine to a repair shop and they said there was an issue with the line something? circuit board. Quoted me 225 parts 450 parts+labor. Mine was a red tinted screen.
Jan 17, 2007 | Philips 55PP9701 55" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 55PP9701 55" Rear Projection Television Logo
196 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
