I have a wireless network adapter and its not connecting to my wireless network. when i put it in its going to profile settings and asking for a key. where will i find this. im not so good when it comes to computers so make it simple please
    Champion:
  • 253 Answers
Http://192.168.1.1
http://192.168.0.1
http://192.168.1.0
Try this and go to the wireless settings, or which router do you got?
Posted on Dec 01, 2008
I bought a new N300 today, and am having trouble connecting my old wg111v3 adapter for my old desktop (my new laptop works fine). I named the new wireless network the same as the old G network, but I...
Assuming you're using the Netgear Smart Wizard software, go to your settings screen and delete all the profiles. After that, create a new one and put in the settings for your NEW network, then save it.
May 10, 2011 | NetGear WG111 802.11g/b Wireless Adapter
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
ICANT CONNECT WITH MY NEW DELL NETBOOK WITH MY WIRELESS WGT624 CANT GET IP ADDRESS INSTALLED
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Jun 20, 2009 | NetGear WGT624 Wireless Router
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a...
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
Apr 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Limited or no Connectivity WG111v2 SBG900
Limited or No Connectivity on Windows XP
Feb 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
"security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx In principle: Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1 Enter (admin) for the user name and also for the password. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Dec 19, 2008 | D-Link Wireless
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
May 21, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Password Problems
Maybe you are getting LIMITED OR NO CONNECTIVITY. This happens when the wireless adapter is able to find a network but the pc cannot get an ip address. One of the reason for that is that your wireless network might be secured and you missed to enter the correct network key when you were asked by the computer. The wireless security is set on the wireless router, SO WHEN YOU SET THE PROFILE ON YOUR WIRELESS ADAPTER, YOU SHOULD ALREADY HAVE THE WIRELESS SETTINGS FROM YOUR WIRELESS ROUTER. THEY HAVE TO MATCH FOR YOU TO HAVE A COMPLETE CONNECTION.
Mar 10, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
