Question about Kodak EasyShare Z650 Digital Camera
MAx SD size that works in a Z650 Digital camera
I added a 4 Gig SD card and it keeps saying to format the disk,
What is the Max SD size you can install
  • 3 more comments
  • Anonymous Dec 11, 2008
    I have the same problem. Our internal memory is full so we bought a 4MG SD card and now cannot format the camera. We tried to format using the menu and manual, but that didn't help either.
  • hunterjenn Jan 20, 2009
    Same here. My 2 g card works fine, so I'm guessing that's the max. Isn't it frustrating? That error message over and over....
  • Anonymous Mar 17, 2009
    Yes same for me, I think it is kind of strange.
  • Anonymous Apr 14, 2009
    Had the same experience with an 8GB card.
  • Anonymous May 24, 2009
    4GB card, same problem....
  • 262 Answers
You can use 1GB SD card or 2GB SD card., more than 2GB is not compatible on your Z650., Gudluck!
Posted on Nov 04, 2009
I tried 4GB SD card but says to format continuously. But 2GB SD works fine
Posted on Nov 24, 2011
Easyshare kodak Z700
The Z700 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
Apr 27, 2014 | Cameras
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
Will my kodak z650 take a shdc memory card and how do i format it
No. The Z650 only takes SD cards, up to 2GB in size. You cannot format an SDHC card in one.
Jul 31, 2010 | Kodak EasyShare Z650 Digital Camera
Max size sd card for z612
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
Jun 12, 2010 | Kodak EasyShare Z612 Digital Camera
I have a Kodak Easyshare Z740 & we just purchased an 8gb sdhc SanDisk & it keeps saying it needs to be formatted it says everything will be deleted and then goes back to disk needs to be formatted...
You need to buy an SD card. the Z740 works with SD and MMC cards, not SDHC cards. While SDHC cards will fit into an SD slot, there are hardware differences which keep them from working. SD cards will work in SDHC devices but not the other way around.
Again, you need to use SD cards, which max out at 2GB. Anything larger is an SDHC card, which does not work in your camera.
Apr 26, 2010 | Kodak EasyShare Z740 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
I just bought a SD card and when i put it in my camera it says its full but i just bought it havent took any pics or anything and when i go to format it it says FILESYS ERROR e000 100
What is the capacity (max size memory card) that your camera will accept? Error message may be that you have exceeded that capacity. My FujiFilm S700 required a firmware bios flash upgrade for it to be able to take the newer 4 gig cards. Used to max out at 2 gigs. If this has helped, please rate it accordingly. Good luck.
Jul 05, 2009 | Kodak EasyShare C330 Digital Camera
2 gig sd card problem
I found a user manual online says max memory is 256mb on this camera. Wont recognize anything bigger.
Here's the manual in pdf
http://www.theusermanualsite.com/mdownloads/3d5c169f-850c-2724-ed2c-2d458174b40a.pdf
Aug 15, 2008 | Vivitar ViviCam 3715 Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
575 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
