Question about Insignia IS-PDVD10 Portable DVD Player
Insignia Portable DVD Player does not play DVDs - says no Disc?
    President:
  • 814 Answers
Unit needs to be returned for service under warranty. If not under warranty. You Must open the unit by removing all the screws on the bottom of the unit and use a small plastic pry bar to open the case around the space where the volume control is.slide the pry bar all around the case to open it.Becareful not to lose any of the switch cover that may fall off as you open the case. You must replace these covers exactly to operate the unit once reassembled. Check all rubber bumpers for hidden screws before trying to open the case. you must unlock the plastic locking mechanism all around the case. Then take apart the laser and motor assembly and disconnect all the wire straps and ribbon cables. Clean all these connectors with a contact cleaner by apply it to a cotton swab and cleaning. Try cleaning the laser with a cotton swab and Isopropyl alcohol. Put small amount of alcohol on swab and gently clean laser lens, Check transport for dirt and try cleaning the travel rails of the laser to remove dirt and grease and reapply a small amount of lithium grease to a swab . Lube the rails and ratching mechanism. Do all this with the utmost case, do not use to much grease or you will cause more problems..Use light gloves. do all the work with the cotton swabs. Check disc spindle and see if it is loose, if it is use a drop of super glue to to tighten the grip of the spindle to the motor shaft.Reassemble unit and put together in case put all screws back in unit and test unit on a level non vibrating surface. Use a clear disc from CD cases to check and see if laser is turning on and attempting to track normally. If this does not work attempt to polish laser head with soft foam material and non abrasive high gloss mirror or glass polish very carefully try to make the laser clear and shiney. Do not work to fast and do not push to hard on the laser or you will ruin the alignment.Slowly try to clear the lens of all discoloration.If all this fails try to buy a new laser mechanism from e-bay and replace your old one. Hope this helps you with your problem.
Posted on May 10, 2009
Posted on Jan 12, 2009
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Aug 13, 2009
John-INSG
  • 312 Answers
SOURCE: Hi my portable dvd player by insignia won't read
Try using a lens cleaner. Also, reset the unit to factory defaults. Ensure that the disk you are attempting to play is clean and scratch-free. If the problem persists, you may pursue service options through the place of purchase.
Posted on Jul 01, 2010
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Jun 20, 2010 | Insignia NS-PDVD10 Portable DVD Player
Foreign disc messed up portable dvd now it wont play british dvds
Croikie!!!
See if there's a factory reset option in the menu
Also,try cleaning the laser lens with 90% alcohol and a swab ( Gently) then buff it dry
Apr 19, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
Regional codes
can you please inform the model number?.
each player has its own way to unlock..
Oct 28, 2008 | Insignia IS-PDVD10 Portable DVD Player
Dvd does not play
The problem is the laser. CDs and DVDs use a different frequency (color) of light. One can fail or weaken and the other still be strong. Check with Insignia for repair.
Aug 18, 2008 | Insignia IS-PDVD10 Portable DVD Player
DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
Jul 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
My insigna I-dp720 won't play dvds
My Insignia DVD player says that there is no disc in the player, although it's in there... What can I do?
Thanks. S.
Jan 06, 2008 | Insignia I-PD720 Portable DVD Player
Insignia portable dvd player
It sounds like the player needs to be cleaned. Just go to your local electronics store and get DVD player cleaning disk. They are only like $10 and do the trick. Whatever you do, DONT blow into the player as it will only make it worse.
Dec 31, 2007 | Televison & Video
DVD player won't play audio cd
clean the laser lens as they could be dirty,if that does not work take it to a tech for a check and repair.lens might need to be replaced.
Mar 16, 2007 | Insignia IS-PDO40922 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
583 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
