Question about Refrigerators
I have a magic chef refrigerator freezer model csd2725ar. Both the refrigerator and the freezer will run fine for a couple hours to a couple days. Then the refrigerator will start freezing things. So, We adjust it down. Then the temperature in both the Freezer and the refrigerator will increase to unsafe levels...the freezer stuff will start to thaw...icepops will melt. This happens off and on without us adjusting the temperatures, too. What do we need to do...any advice would be appreciated. Thank you!!!
  • de-ice Dec 22, 2008
    I have a Magic chef refrigerator freezer top model RB214A the fridge portion (bottom) ices up on the very bottom and freezes all food products.
    Sergeant:
    Champion:
  • 311 Answers
Bad cold control needs to be replaced from what you are saying.
Posted on Nov 28, 2008
I have a magic chef refrigerator.Model number CTL1911DEW. compressor is fine, freezer is fine. Light is off on refrigerator thermostat and its not getting cold D
There is a fan which brings cold air from the freezer side to the refrig and sounds like it is not running.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 25, 2018 | Magic Chef Refrigerators
Magic chef RB150R freezer won't cool, refrigerator sorta cools. Freezer fan runs all the time
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 13, 2018 | Magic Chef Refrigerators
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
