Question about Polaroid FLM-3734B 37 in. LCD HDTV
No picture is there some sort of re-set on the tv? I can unplug the tv and the red light will come the front to let me know I have power. I can then turn on the tv and the blue light comes on but, no picture...... After thid the tv's blue light will not power off by re-mote or at the tv. What is the deal.... The tv is not that old..... Gerald
  • michaelantho Nov 30, 2008
    my tv has power but no picture. same problem red light comes on press power & blue light comes on but no picture FLM-3732 same tv michaelanthonyson@gmail.com
  • moneythomas Dec 05, 2008
    Where do you find a power supply for a 37 " Polaroid LCD TV? How much does it cost?
  • 2,326 Answers
If your TV is less then a year old, still cover under manufacturers warranty, if not the solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 28, 2008
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Tv will not power up blue power light flashing,red temp and red lamp lights flashing
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Oct 11, 2009 | Hitachi 50C10 LCD TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Samsung HCL552W
these have been know to have bad convergence ic but that would only be a guess as to whats wrong i would have someone give you and est.
Jan 14, 2008 | Samsung HCN4226W 42" Rear Projection...
My 32in sdtv red power light,no pic no sound
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Oct 05, 2007 | RCA 32F531T 32" TV
No sound, no picture and a red light blinks on front panel
If I remember right the set is blinking a code, dont remember which code, but what happened something on the power board failed and knocked out the 5vdc regulation? The power board will most likely need replacement, this should be done by a qualified technincian or someone who knows how to dissassemble/ repair set.
Jul 07, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
No pic or sound
All the TV's have a fail safe now a days. It looks like that there is a problem with color management or the picture tube. If this is a projection than I could have said that it is a certain that it is to do with the color management. When Tv tries turn on it get a signal that there is a problem when it does the diagnosis prior to turning on and it stops. I am leaning towards the Picture tube as you didn't mention that the power light goes off after it tries to turn on. Please get it checked. good luck.
Jun 16, 2007 | Samsung TXN3071WHF 30" TV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
162 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
