Question about Datamax Allegro2 Thermal Label Printer
Datamax allegro2 error
Ribbon and paper light is coming on when we try to print
  • teiko1986 Jan 12, 2009
    i have the same problem but still cannot print,can attach with solution and pic for me how u resolve this problem?
If you have it set to use thermal ribbon and dont use 1 then you can get this error..
put a ribbon in or there is a switch located inside the case near the feed switch turn it off
Posted on Jun 07, 2008
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
I have a w class data max printer and it prints the labels but very light ink on it i was told that the green wheel on the side controls that but i have tried every single level on it but still light...
Lift the print head (where the label comes out and the ribbon should be right under it)
Take a clean Q-tip and some IPA, and wipe the little black line of dots you will see inder the head. These are the thermal points on the print head and they do build up debris which moves the head away from the ribbon causing lite print.
Dec 30, 2010 | Datamax M-4208 Thermal Label Printer
I need drivers for this printer for working in Windows XP pro
aldorobert20: Download driver in datamax-oneil.com or in seagullscientific.com
Roberto Martinez
padrino99@prodigy.net.mx
Nov 09, 2010 | Datamax Allegro2 Thermal Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Printhead leaves impressions but no print
Sounds like you've run out of ink? If not then the ink has become dry and clogged the head.
Try using a alcohol solution (white spirit or a strong liquor like vodka will suffice) with a piece of paper towel to clean the head of the ink cartridge, then try printing a few times until it works well.
Otherwise, sounds like the cartridge needs repalcement.
Jul 02, 2009 | Datamax DMX I-4206 Printer
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Allegro2 Print Too Slow (25 seconds send from Windows XP)
miaharoon: Printing via Windows driver it's too long time because the driver sent a lot data to printer. Also the print speed via serial port it's slow. Inside driver, install Datamax printer fonts and barcode fonts to use it in Windows programs.
Roberto Martinez
Jul 22, 2008 | Datamax Allegro2 Thermal Label Printer
Datamax Allegro2 Thermal Label Printer Logo
344 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
