Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Pilot light does not flow gas
Empire Corcho ventless wall heater model CH-18-1
There is gas flow into heater case and through in case regulator. No flow past the control valve, to which everything els is connected.
  • 61 Answers
Change your theromcouple
Posted on Nov 29, 2008
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
My empire wall furnace does not ignite. It has gas flowing because the pilot is light, i have changed the thermostat and wired it two different ways in case I reversed them. What is next? Could it be the...
It could be several things: Is the Control Knob turned from Pilot to ON? If that is the case, wait a few minutes after turning it to ON. That will allow the Thermopile to heat up sufficiently. Be sure the flame is touching the Thermopile. If everything looks correct turn up your Thermostat to higher than the ambient room temperature and see if the burners light. Remember to turn your Wall Thermostat down to the lowest temperature setting before turning the knob from Pilot to ON.
FYI - That Wall Furnace does not have a Thermocouple. It uses a Thermopile instead to generate millivolts of electricity to open the gas valve and maintain the pilot flame.
If it is the Thermopile, you can order it directly from Empire Comfort Systems, as well as download your Owners Manual at www.empirecomfort.com
Feb 04, 2011 | Empire GWT-50 Wall Mounted Panel Heater
I have an empire corcho model 15-1. It will not light with the ignition button what are the possible problems? LP gas is to the unit.
ignition out of postion , it needs cleaning , end of ignition brunt off or too short, blocked pilot, ignition shorting out on heater causing short spark
Nov 28, 2010 | Reddy Heater RLP100 Portable Forced Air...
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Empire corcho ventless propane wall heater 15000 btu
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Oct 04, 2008 | Reddy Heater RLP100 Portable Forced Air...
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
Heating & Cooling Logo
662 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
