Question about Plantronics PL-CS55 Wireless Headset
Person on the other end receives a bad feed back when I am talki
I just put a CS55 Plantronics wireless headset with a HL10 lifter on my NEC phone and they people I am calling cannot stand the feedback they are getting when I talk. I know these will work because someone else in the office has the same system.
Any suggestions on what I should do?
  • barry moe May 05, 2009
    I have a CS50 and it recently started causing annoying feedback to the people on the other end of the line.
  • 83 Answers
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
Posted on Jul 18, 2009
  • 5 Answers
The major setting for these headsets are underneath. Setting "B" is the factory setting, you can experiment with A, C, or D as well if this does not work.
Round dial should be set to "0" (picks up dial tone, adjust if no dial tone) and intelli switch to - not =
But try the settings underneath first, this will make or break it.
Try also to keep it as far away from the phone as possible.
If there still is feedback, contact Plantronics, or where you bought it from, it is likely defective.
Richard
www.telecomsuperstore.com
Posted on Nov 19, 2009
Hi, one of our Call Center workers cannot hear the ringing phone when she has the headset onWhat's your problem?
The ring from the telephone is picked up by the internal microphone on the HL10 Handset Lifter, typically for most phones, the lifter sits directly over the speaker grill on the telephone where the sound comes out. For telephones that curve out on the left side and don't have a straight edge, there is an accessory called a "Ring Detector" which is used. Here's a link:
HL10 Nortel Adapter Kit - 46780-01
If the internal mic on the lifter has gone out, you can plug the ring detector into the handset lifter and just stick the ring detector over the speaker grill to pick up the ring. Plugging this into the lifter will bypass the internal mic, this accessory would have come with your HL10 lifter. You can also check the ring volume on the telephone, and you can also try adjusting the ring tone on the phone (sometimes it will pick up one ring tone better than another). Here is a link below if you need to order a new ring detector:
HL10 Nortel Adapter Kit 63014-01
Good luck from Headsets Direct!
Oct 27, 2011 | Plantronics PL-CS55 Wireless Headset
HL-10 LIFTER DOSEN'T STAY UP AND SLIDES DOWN FREQUENTLY.
The internal gears on the Plantronics HL10 may be worn. You can take the handset receiver off hook and try manually raising up the lifter as far as it will go and then slowly pushing it back down into place, sometimes this will help to get it back working properly. If that doesn't work, you may need to replace the HL10 lifter. Below is a link where you can purchase a new lifter.
Plantronics HL10 Handset Lifter
Aug 30, 2011 | Plantronics CS70 Wireless Headset
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Good Luck from Headsets Direct!
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
Incoming call alert
May 17, 2011 | Plantronics CS55 Wireless Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
I am getting feedback and an echo in my Plantronic CS55 wireless
Had similar issue.
This how I fixed it
1) set bottom mic to A
2) set dial on the side of CS55 to "Setting 1" most typical
3) set sound lever on the back to "1"
4) played with mic control on the back until quality became sufficient
Jun 26, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Dec 12, 2008 | Avaya Definity 6408D Corded Phone
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Plantronics PL-CS55 Wireless Headset Logo
291 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
