Question about Pioneer VSX-D607S Receiver
No sound from Center, Rear & Sub speakers on Pioneer VSX-D607S
I just got a Pioneer VSX-D607s A/V Receiver. Its 5+1 surround sound. I have hooked up a speaker I know works to the center channel and one to the rear, and also plugged in the subwoofer, and then connected a CD player.
The problem is I am not getting any sound from the speakers. I checked and I put it into DSP mode and turn the subwoofer ON and still nothing.
If I hook the speakers into the other speaker inputs (not the center or rear channels), then I get sound, but nothing out of the center or rear, and nothing from the subwoofer.
Will these only work if a 5.1 signal is received, such as through a DVD player? The manual says squat about it
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
caroldon
  • 17129 Answers
SOURCE: I lost the remote to my Pioneer VSX D607S. I am
I dont think so as most of the sub functions are placed now on the remote control with no parallel modes on the customer panel.
The other way around is to trigger the circuit manually in the circuit but this needs care to allow the sub to switch on..
Posted on Sep 29, 2010
  • 1340 Answers
SOURCE: I brought recently a few
I can answer this but I need a couple of answers to questions first please.What is your main input?i.e.cable ONLY,cable box,dish,or antenna with digital converter(not likely these days but have to know).Also,do you record on the VCR and/or the DVD?Also,is surround sound what you want to connect or basic 2 or 4 speakers?Also,do you record with the CD and/or tape player?It may take a couple of tries with the EQ because i haven't done one in a long time,but I will get you setup properly with the answers you provide.So when you answer,I find it best on something like this to open a separate box and go through each reference answering,cable box,Yes record VCR,no record DVD etc. Many times people which I will ask something will just say yes or no,without referring to what they answered and it takes a week to get it right.Thanks,Greg
Posted on Nov 23, 2010
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I lost the remote to my Pioneer VSX D607S. I am trying to turn on the Sub-woofer, but the manual only shows how to do that using the remote. Is there a way to turn on the sub-woofer manually?
Sep 29, 2010 | Pioneer VSX-D607S Receiver
The reciever is connected to my subwoofer but Im not getting anything out of my subwoofer.
You need to instruct the receiver that it has a subwoofer and then tell it if it should share the bass with other speakers. Read the manuals for both the receiver and the subwoofer. AVR's take some setting up. Subwoofers are never assumed to be installed.
Aug 19, 2010 | Pioneer VSX-D607S Receiver
Pioneer vsx-519 no sound from center and surround
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer receiver vsx-d510 sub not working
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Feb 05, 2009 | Pioneer VSX-D608 Receiver
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Pioneer VSX-D607S Receiver Logo
211 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
