Question about Hobart A200 Stand Mixer
Hobart a-200 3rd gear lock-up issue
Gears 1 & 2 work fine. When in 3rd gear, shafts lock up after very minimal rotation and worm shaft tries to lift upward. I'm turning this by hand when in 3rd gear so as not to do further damage. Hobart tech charges 99 per hr, and takes cigarette break every 20 minutes! I've torn down and re-assembled, but cannot find any causes. No broken gears or keys. Possibly sabotaged by factory tech during last service call, when he left machine partially dis-assembled. Part(s) or shim(s)missing? If I loosen planetary shaft a couple turns and tap it down, it'll work but with obvious knock. Seems to engage 1st and 3rd gears at the same time causing lockup, but can't figure out why. HELP!!!
  • cripple358 Jan 01, 2009
    Diving-key type. It's fine now. The $125.00 per hour "factory tech" flipped the top gear and placed it back in the grease. Intentional or just stupid, I don't know. Once I installed the gear properly, everything worked fine. I had to tear down one of our other mixers to double check everything, which is how I discovered the flipped gear. But thanks for the reply!
  • 49 Answers
Do you have a spauge cutch first gear or a diving key locking type? sheck shifting collar for being rounded off on the gear and the collar they get rouned off and won't lock gear in.
Posted on Dec 29, 2008
  • doobo67 Jan 01, 2009
    yes it won't lock in just click or tick
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
Hobart a200 will run just fine without anything in the bowl, once I pour my ingredients into the bowl, it wouldn't even mix the ingredients. Try all 3 gears.
Short answer: something is worn/broken inside the mixer's transmission.
Longer answer:
Since none of the three gears operate, the problem is most likely on either the worm gear shaft (probably the brass worm gear itself) or the "transmission shaft" (ironic name as all three shafts could be called transmission shafts). If you're up to the task of disassembling the transmission, which is a very messy task, you'd probably find the problem on one of the two smaller shafts inside the transmission. You'll most likely find either a broken key or worn brass worm gear. Both of these items may have enough holding strength to operate under very light loads (such as an empty bowl) but slip once a load is presented.
Also check the planetary key. Remove the planetary by removing two nuts on the underside of the transmission, where the attachments attach (careful, as the whole thing will drop once the second, thin nut is removed). You will find a long key on the shaft (or in the planetary gear, whichever one it sticks to). Make sure it's not broken, and re-attach the planetary.
Aug 12, 2010 | Hobart A200 Stand Mixer
I need a repair manual and parts manual
Once you're familiar with it, the A200 is OK to work on. Just pay close attention to the sequence in which the gears are removed and lay them out on a table in that sequence. You'd need to remove most of the gears from the center planetary shaft, which requires removal of the shift lever (right side, 4 screws). You shouldn't need to remove the planetary (lower end that holds the attachments and rotates). Eventually you'll be able to remove the smaller shafts as assemblies and replace the brass worm gear.
You'll want to scoop out the grease with brass shavings in it (replace all the grease to be thorough, especially if it has broken down and is very runny or very thick (the grease should be a little bit thinner than the consistency of peanut butter), spin the removed bearings by hand and listen for rough operation (particularly the smaller bearings on the upper end of the two small shafts (bearings in the upper bearing cover). Also check to see that the two brass bushings, which reside in two of the gears removed from the center planetary shaft, spin freely BOTH on the planetary shaft AND in the gear they reside in (if not, one of your speeds probably won't work).
For an experienced technician, the job would take approximately 1-1.5 hours unless the old grease is all cleaned out thoroughly to replace with all new grease (thorough cleaning requires the removal of planetary and planetary shaft), and thorough cleaning can be a time consuming process. Then you might get closer to 2.5 hours.
May 07, 2010 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Loose gear
Lock out-Tagout the machine. Remove the top cover, hold the beater shaft while removing the center shaft nut. Then remove the 4 bolts and and hardware on top of the first(worm) shaft and the second(clutch)shaft. you can gently tap the top cover up with a cold chisel on the upper parts of the housing. It's just a friction fit , aligned on two dowels. Once the cover is off, scoop out the grease, remove the side panel and selector assembly. Try and lift all of the first gear assembly together. the newer ones have a series of rollers and springs, which can be easily reassembled, if you see which way everything was. As you rmove parts, lay them on a clean surface in a row in the position they came out. The selector sleeve is marked TOP, but looking at the 4 drive teeth each side, you will see how it drives 2nd and 3rd gears. The clutch and worm shafts lift out together from slip fit bearings in the housing base.
When reassembling, coat everything with new grease, and run before loading all the grease. If you need to remove anything , you won't be up to your wrists in grease doing it. Once all is good, load the grease in the top hole nearest the motor with it running. The gears will feed the grease as you load the 35 OZ.
If you removed the planetary to remove the center shaft, don't tighten the half nut tight. back it off a half turn and lock it with the acorn nut. Otherwise you will loose first gear from pinch friction.
Sep 14, 2009 | Hobart A200 Stand Mixer
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
Jan 09, 2009 | Hobart A200 Stand Mixer
Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
Oct 24, 2008 | Hobart A200 Stand Mixer
D300
See if all the gears are dead. This will indicate which key may be broke. If all the gears are gone, look to the small shaft with the brass gear. It engages the motor worm gear.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/08082CF4BE829A3C852568E1006A9A00/$File/F-19118%20(07-94).pdf
Apr 23, 2008 | Hobart D300 Stand Mixer
Hobart A200 Stand Mixer Logo
151 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
