Question about Gateway FPD1975W 19" LCD Monitor
Monitor Hi I have a gateway mitor two that flashes you talked about caps where do you get them and how do you install them
You can get the capacitors at any radio shack or online electronics store. You will need to solder the old ones out (heat the contact point on the board) and then re-solder in the new ones in there place. Make sure that the stripe on the side of the cap is positioned the correct way.
Posted on Dec 18, 2008
Gateway monitor issues, "FDP2275W TFT
This model is know for having bad caps problem as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/Gateway%20FPD2275W/
That will be the first place to inspect, you MUST be real carefull when opening up this monitor since you can easily damage the ribbon cable attached to the front bezel.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 26, 2011 | Gateway FPD2275W LCD Monitor
I have a gateway monitor and it has a theft determent password and I have no idea of what it is. All I did was to move the monitor from one PC to another and now it won't work on any computer. I tried...
Gateway support is bad and you may not be able to proof to then that this monitor is yours.
You need to install EZTUNE but you will need the password, hope you can get it!
Read more here:
http://www.fixya.com/support/r4558549-gateway_lcd_monitor_eztune_theft
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Dec 29, 2010 | Gateway Computers & Internet
I am curently hooked up to a spare monitor because every time I plug in my FPD2275W monitor it flashes on for a moment with an odd VGA picture and then it goes black. I don't know what to do.
It may have dying power supply as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
This is not easy monitor to take apart and you MUST be real careful on the ribbon cable attached to the front panel.
Dec 11, 2010 | Gateway FPD2275W LCD Monitor
My gateway monitor flashes gateway logo then it (FPD 2185 W)
Look for bad DC filter caps in the power/inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jul 27, 2010 | Gateway FPD2275W LCD Monitor
X2gen mw19u monitor is off but the ''no signal'' light keeps flashing on and off. When I power up the computer, it continues to flash on and off. You can see that the computer is powering on and going...
Hi Steven,
You are getting "No Signal", indicates that CPU is working fine. Check with another monitor or desktop, if it is working gateway monitor is in risk. I recommend you to check with Gateway technician.
Jun 14, 2010 | Computers & Internet
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor flashes on but with 1-3 seconds it goes to balck screen. I've replaced the electrolytic caps in the power supply, but it didn't help
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Mar 10, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway 19 inch fpd1976w problem
Power supply will be the first place to look, look for bad caps (bulging tops or bottom seals). Check it out and post back what you find so we can guide you further, see example of failed monitors due tobad caps: http://s807.photobucket.com/home/budm/allalbums
The high pitch you are hearing can be from the bad lamp soldering connection, it is arcing.
Jan 24, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Monitor won't turn on, just keeps flashing the gateway logo on and off
Unless there is inadequate ventilation, your monitor could remain on all the time with little ill effect. Actually turning on and off your monitor actually puts more strain on it then leaving it on all the time.
If the gateway screen is displayed for a moment and then just turns off, I believe the inverter board inside the monitor has broken.
What's actually happening is that somewhere in the board more voltage then needed is "leaking" in and the safeguards on the board turn it off to prevent damage.
I would go and get an estimate from a shop. If the price is within 30-50 dollars of a new monitor, get a new one.
Mar 14, 2008 | Gateway FPD1975W 19" LCD Monitor
Monitor keeps flashing "Auto processing"
Hi
Do a factory or monitor reset from the monitor menu.
Jan 01, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
