Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD440 Machine stops after 60 seconds
When I start a cycle the washer fills up with water then stops, The on/off button flashes as does drying high heat, reduce creases and time saver. Tried unplugging for several minutes but it does not help. Is this a software or hardware problem? Machine is three years old and has been otherwise excellent.
  • Tom_Dub1 Nov 28, 2008
    LarryB ,
    When you say expensive have you a rough idea of cost and will I need an engineer to install it? My basic question is whether it is worth repairing at all.
    Tom
  • Tom_Dub1 Dec 04, 2008
    Solution was helful
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try to fool the machine into completing a program:
  • run the machine as you normally would;
  • soon as the flashing starts, set the timer to the same time as you initially had set it;
  • rotate control knob to "M";
  • one of the flashing lights should switch off;
  • allow to machine to cycle itself for about 5 minutes without user intervention;
  • power off the washer.
Should the above be not corrective, you may need to replace the controller/logic board. In some instances, a firmware update would also be required. The EPROM would require re-flashing. Unfortunately both are not user workable.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
    Champion:
  • 291 Answers
Hate to tell you but you have a bad control ,,, the control operates all parts of your machine / replace control and it will be ok but it is expensive / larryyb
  • Larry Youngblood
    Larry Youngblood Nov 28, 2008
    tom that board can run up to 300.00 and yes you will need a tech to install that one ..... sorry for the bad news / larryyb
Hi i have a hotpoint aquarius wd440 14000 spin i have flashing lights on the on off and on the drying heat. It is a washer dryer .but I never use the dryer. can somebody please tell me what's
I believe your issue is a blocked/clogged water drain. If your unit appears to drain all of the water at the end of the cycle, you may just need to clean your filter. The machine can sense when it takes too long to drain and it flashes those particular lights to let you know what the problem is.
Dec 22, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
