Question about Whirlpool Dishwashers
Whirlpool DW heating element removal mod.#iud8000rso
Trouble shoot light suggests heater element bad, trying to figure how to get present one out. Tried to turn with vice grip but verrrry snug , dont want to make worse , any suggestions, ... part costs 23 bucks
  • rokloj Dec 01, 2008
    hi,
    Thanks for getting back...
    Seem to be metal. Part diagram looks what seems to be like a gas filter on a car... sleeve- with plug in posts on bottom.I did try with pliers and did see some particles come off ;like dust..parts diagram shows cylindrical nut under top " retainer" wish I could draw diagram .
    This is a model IUD8000RSO/ whirlpool Part #AP4325066, Has a pretty good diagram, but ????? Its so snug I really dont want to make matters worse by forcing without consultation...
    Anything You can offer will be much appreciated...
    Thanks Richard
  • rokloj Dec 05, 2008
    The heating element is round and the ends actually go into the bottom of washer: there are round "fasteners" which the element go thru.. No way to use box wrench,only way to turn them is with channel locks ??? what is under the tub, and do these fasteners screw out , or pulled upward like a plug? How do You get the heating element out ?
    Sergeant:
    Champion:
  • 291 Answers
To replace the element you have to pull dishwasher out from under cabinet and then it is easy to replace by taking off the 2 nuts holding it down and removing the 2 wires / larryyb / be sure to kill power to dishwasher before starting
Posted on Dec 05, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls confirm the model, your post "IUD8000RSO" or could it be "ADP 8000".
Alternately, if things are stuck, might it be possible for you to check for continuity. The actual component need not be removed, just one of the wires leading to it. A DVM or VOM can then be used to check. If there is no continuity, then it could be forced out since it is already defective, however if the continuity proves that it is still intact, then there would be no need to remove the heater. Another component that directly interacts would be the thermostatic switch or fuse. If this is open, then even if the heater is good, the unit will not heat up.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
    Champion:
  • 338 Answers
Sometimes the nuts holdint the element are very tight you can try having someone push down on them while you use a deep socket to remove them or just muscle it out. you shouldnt be able to do damage to the part because it is broken. :) however use the deep socket and muscle it out.
  • 734 Answers
These nuts are located under the dishwasher and you probably have to remove the dishwasher from the cabinet to access them.
- The part number for the heater (including two rubber washers) is AP4325066
  • futureloginn
    futureloginn Dec 01, 2008
    try the following links -----
    http://www.appliancepartspros.com/Applia...
    http://www.repairclinic.com/0088_9_1.asp...
Pots and pans light keeps blinking and not working on Whirlpool Gold Dishwasher - what do I do?
Pots and pans requires HOT water. If your heater is not working it will not run the cycle. Possibly the heating element is bad or has become disconnected. Only has two wires coming in from the bottom of the dishwasher (underneath behind the kick panel). Do not touch them unless you know power to the DW is off. Heating element is nothing but a high resistance wire in a tube so you can check it with an ohm meter. Continuity means it is good. AS LONG AS that continuity is not with the outside tube.
Not hard to replace it but up to you to decide if it is more trouble than you want to do.
Sep 15, 2012 | Whirlpool Dishwashers
My whirlpool dryer no heat mod ler8648pg1 help please..
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 01, 2011 | Whirlpool Dryers
This dw is not cleaning tea stains off cups. My older whirlpool did so just fine. One issue I see is that the detergent is not fully dissolving and gets stuck in the detergent door or is in a lump on the...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 13, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Will run but will not heat up
Most likely a bad heating element and or bad thrmostats. you'll need to check these by ohming out after removing the rear panel to your dryer.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
Oct 26, 2009 | Whirlpool Dryers
HOW TO REPLACE HEATING ELEMENT
Turn off the electric panel breaker that powers the unit! Check to make certain it is off before proceeding.
You will need to disconnect the Dishwasher (DW) from the electric, water and drain lines and remove it from under the counter in order to be able to access the underside of the DW. There you will find two (2) wires connected to the heating element along with a couple of fasteners that hold it in place. Also check inside the DW for any hold down clamps, etc. on the heating element there.
Once you have removed the connectors and mounting screws, you can then remove the element from the inside of the DW. You will need to "pop" out the grommets that the element passes through from the inside to the underside of the DW, as these keep water from leaking past the elements. Just remove and save those grommets and reinstall them onto the new element and slip it back inside the DW and through the holes in the floor of the unit. Reconnect the wires and re-fasten the screws or clamps that hold the element in place and reinstall the DW back under the counter, reconnecting the water and drain lines and the electric power.
This is a fairly simple and money saving repair for the DIY'er and well worth the time it will take you to perform the replacement. Good luck and hope this helps. Here's a link to the versions of your DW that will show you what it looks like for the parts and placement for your specific unit as I couldn't locate an exact match without the rest of the model number series. Just select yours and look at the diagrams to find the heating element on the inside of the wash tub.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GU980SCG&pop=flush
Jul 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Is heater element bad
Does sound like the element is bad, confirm with a multimeter, should see 120v across the element terminals, if voltage is present check for continuity of the heating element with the power off, no continuity equals bad element.
Feb 23, 2009 | Whirlpool Dishwashers
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be...
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Feb 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
