Question about Coby TVDVD2050 20 in. TV/DVD Combo
Blue green line
I just got this television for christmas and about the third time i turned it on it suddenly had a blue/green line at the top of the screen that goes about 3 inches down. What setting do i need to change to get that off. Please help!
  • Anonymous May 10, 2009
    i have a coby tv - 1360, it have a blue screen with red lock. please help..... what can i do to remove the red lock.
  • claude_kerr May 10, 2009
    coby tv-1360 have red lock and blue screen, how do i red lock?
I have a tv coby 1360 , now it have a blue screes with red locked. Please help ......What can I do it...
regards
tamara
Posted on Nov 14, 2008
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung HDTV
If you changed the ICs you need to adjust convergence, read carefully the instruction and alingn the lines using remote control commands. Is a long process. My tv loss convergence three times , i will never buy another samsung product. I told every body that i know that never buy another samsung product.
Oct 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Blue vertical lines - no picture
you did not mention if you have sound.but if you have sound your problem is in your video and vertical section.if no sound then you have to look into the IF section.if you are not a tech then you will have to take your set to repairman.goodluck.the tuner must not be over looked.an estimate of about $200.00 could be less.
Mar 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Coby TVDVD2050 20 in. TV/DVD Combo Logo
183 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
