Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
TV shuts off
My TV seems to have a mind of it's own. It keeps shutting down without any input by whoever is watching. When turned back on, it will sometimes stay on all day without any other interruption of viewing. Other times it will shut down 3-5-8-times in a 1/2 hr period before staying on. Other days it may shut down only once during the day, or not shut down at all! I have vaccumed out the vents, the fan is running, I tightened All the electric power connections including all connections in the main circut breaker box. Picture is fine when operating, Cable Co checked input signal everything is OK. Thanks in advance, Dave, Palm Bay FL
  • Samsung Master
  • 13,433 Answers
Its either a protection mechanism and or a overheating issue, how old is it? is it covered by warranty? is it in a well ventilated or cool area in the house?
Posted on Nov 28, 2008
  • 333 Answers
Just try this first. Turn on your tv and then put the remote in another room. You may have a dirty or stuck on/off switch. It seems you have done every thig else. Also change the batteries on your remote.I hope this helps you.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description, would seem to be a loose connection or a colder solder. Most probable triggering would be vibrations from the sound produced by the speaker(s) aggravating the loose connection. One way to test is to use an insulated rod to move/part the wires while the TV set is operational. Of course one must bear in mind the inherent dangers of working with a live set and extremely high voltages. Another test would be to press on lightly on the boards connectors to jar the fault to re-surface.
If it were a loose connector, then re-fitting it back in and making sure that the connector(s) makes positive contact shoould do the job. In certain instances, re-application of heat through a soldering iron on the cold solder should address those issues.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 146 Answers
My computer monitor had a similar issue it stayed on for like 10 mins than shut off unexpectedly and it happened alot more and got worse and then I finally looked up this monitor and found out it had a recall because of this issue.. So I suggest you look up this issue on the manufactures web page or just good it beause you might have the same issue but with a T.V
  • 1 more comment
  • Patrick Shaffer
    Patrick Shaffer Nov 28, 2008
    google*
  • Patrick Shaffer
    Plus Name/Model # I'll do my best to help..
  • Patrick Shaffer
    found this on another site its an exact quote
    "The number one thing I have found with intermitent shutdown is the lamp door switch in the up position.
    This series of models came back from the factory with the switch in the up position and it needs to be in the down position.
    Take a flash light and look through the slots on the lower left side of
    the lamp door in the back of the set. If you can see the top of switch,
    then, thats whats causing your problem.
    Take off the door, there is a tab that holds the switch down. Reseat
    the door and check the switch again with a flashlight. If it is down,
    then the problem is solved. If it is up, try again.
    If you have anymore problems or questions, reply to this post and I will respond."
    Genius:
  • 1,142 Answers
Most probably it looks like a pre convergence issue which can be related to replacement of pico fuse and the bulbs too. Get a good technician who can identify the correct part and replace it.
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
My h1000e takes long to shut down?what could be the cause of this and how do i solve this problem?
Pepper, It seems that you installed something that is causing this problem. What happens is that when you shut Windows down, it has to close all programs running, whether in the foreground or in the background. Now, when all programs are shutting down properly then there is no problem. But when some one decides to resists the shutting down then Windows takes longer to abide by your instructions. You have to find out this/these program/s that you installed recently. Uninstall them if you can do without them. Alternatively close them manually before shutting down. What programs are these? That you alone can find out. Another reason. Does Windows seem to take longer while "Saving Your Settings"? If that happens, then there may be something wrong with Windows. Be prepared to reinstall Windows. Do not get alarmed, but just keep it at the back of your mind. Keep taking backups of your data regularly to be on the safe side.
Nov 21, 2009 | Tyan Thunder h1000E Motherboard
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
When I turn on my A215 S7422 Toshiba it give me a password screen
You may need to consult with whoever you're living with. Seems you got pranked.
If you live by your lonesome, keep in mind that only you can put in a user password. This miracle of some virus, or act of something, is not possible. To my knowledge that kind of virus has to be user specific. Targeting you only.
Contact Toshiba for password woes.
Jul 14, 2009 | Toshiba Satellite A215-S7422 Notebook
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55513 screen keeps turning off
Yes, if you are handy, you can leave an e-mail address and I can send you a how to do repair guide with the factory service manual for your TV set and you will save at least 800 to 1000 bucks!
Jan 08, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
