Question about Frigidaire GLEQ2152ES Electric Dryer
There is a squeaking sound when running the dryer
Therre is a loud squeaking sound (like a bad bearing) when the dryer is running. It sometimes goes away after 10 + minutes. I need a repair manual for this dryer.
Frigidair Gallery Elec Dryer
FD648GAHSO
  • Jerry Story Dec 22, 2008
    Squeeking noise from the rear when running. Everything works normal.
  • 333 Answers
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Posted on Nov 28, 2008
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My Maytag dryer MDE9606AZW has started to squeak, sounds like a fast spinning squeak, sometimes loud and sometimes quieter. What might be causing this and how do I fix it?
It's likely your drum ring bearing has worn out. It's a strip of plastic that keeps the metal parts from rubbing has the barrel turns.
Mar 05, 2011 | Maytag MDE8000 Dryer
Sounds like your motor and/or pulley assembly are bad. Try turning the drum by hand. If it turns with some effort then you may have a drum bearing going bad. Does the squeaking sound start right away? Or does it start when the dryer warms up? If so then the bearing is going. If you can get to it spray WD40 for a quick fix.
Jul 11, 2010 | Frigidaire Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
May 03, 2008 | LG DLE2532W Electric Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
467 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
