Question about Compaq Presario M2000 Notebook
Yellow vertical lines on the screen
Two fine paralel lines about an ich from the right side end and 1 single line in the centre came up in the past ten days. can a repair be suggested.
    Sniper:
  • 51 Answers
This is usually an indication of a faulty connection between the screen and the board. Sometimes a tweak rid the lines, but more than not its time to change the screen or just live with it.
Posted on Nov 28, 2008
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
I have a panasonic 48 inch plasma TV which has developed a fault. There is a yellow line down the centre of the screen on all channels. Is the TV knackered?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help in solving the problem.....
Jun 15, 2011 | Televison & Video
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Single vertical red line
Hello Monastirion,
Is the red line there all of the time without exception, for instance when you initially turn on your pc, is it there before the operating system boots?
If so, the monitor itself is most likely broken. I would return it to wherever you bought it, if possible.
Regards,
-Chester
Dec 27, 2007 | LG Flatron L1919S LCD Monitor
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Compaq Presario M2000 Notebook Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
