Question about RCA P61927 61" Rear Projection Television
RCA P61937 61" Rear Proj. No Picture
The TV is 5 years old and there is no picture through the cable input. It doesn't matter if it is the cable or a VCR or a DVD plugged in to the cable port the only way you can see the picture is in the TV Guide plus mode. I hooked up the DVD with an S-video cable and can watch DVD's no problem. Picture looks great and all three bulbs are working. I looked for a reset button on the TV a could not find one. Is there a simple fix for this?
  • rryoti Aug 27, 2008
    Anybody figure this out as I have the same problem
techman
  • 3130 Answers
SOURCE: 61 inch proj. warped concave picture.
convergence power supply problem
Posted on Jul 01, 2007
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
i dont have a soultion for you but can tell of my experince with rca 52"dlp after having mine for six months did same thing sent it to the repair shop it stayed there for three months then they said they couldnt fix it tried to talk to rca cust serv reps who basicly said they didnt care after two more months i finaly got the store manager where i bought it to go to bat for me and they agreed to replace it but with a lower grade model and no warrenty as they said mine had expired even though it had been broken for eight months after three months the new one did the same thing i was told it was the light engine which cost 2 grand and were on forever backorder and id just get another tv before putting that much in that tv but it wont be another rca hope this helps now i have a 100lbs paper weight b4829@yahoo.com
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: no picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
SOURCE: RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Posted on Apr 03, 2008
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 50in. Rear Projection rear inputs chop off top of screen
Try pressing the TV button on the remote then pressing right or left arrow buttons on the remote.
Mar 06, 2010 | RCA Televison & Video
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
NO Picture On 2 Video Inputs ( 1 front 1 rear ) : Sound OKAY
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
Dec 13, 2006 | Sony KV-36FS12 36" TV
RCA P61927 61" Rear Projection Television Logo
593 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
