Question about Samsung LN-S4095D 40 in. LCD HDTV
Samsung LN-s4095D LCD (Slight picture scrable, lines of static)
I have this 40" LCD Samsung TV that I just purchased. The screen is in perfect condition there is nothing wrong with it.
When I turn the TV on with out any type of caples pluged in the picture is fine... the menu is fine, but when I try to hook up my PC or my DVD player (I havent tried it but it's probobly the same with cable) the picture that appears has lines running down the screen.
So basically any type of picture that is being set in is comming out static on the screen.
I took off the back of the TV and dusted it but nothing changed. Does anybody know the replacement part I need? Is it the film? Please help.
4 Suggested Answers
  • 395 Answers
SOURCE: Samsung LN-R408D - No Picture
reseat the LVDS cable inside the unit. this is the cable from the main board to the panel. if the problem is still there then replace the main board 1st, part # BN94-00629F. if the problem is still there then the panel is bad, part # BN07-00245A. if you are not familar with TV repair have a tech repair this for you, if it is under warranty call the manufacturer for nearest repair place.
Posted on Feb 26, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
eagle338
  • 4889 Answers
SOURCE: i have a samsung 40
The fault you have mentioned is caused by faulty capacitors usually those on the Power supply board and/or SSB main board. I would suggest that you take a good look at the board and look for capacitors with swollen or cracked tops. The problem is caused by the caps unable to sustain their charge discharge cycle for a long time due to lost or corrupt electrolyte.
Posted on Nov 20, 2010
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
I have a samsung lns4095d and it has short horizontal white/red lines going down the center of the screen. They jump around, and it's on every screen....setup, cable, hdmi, etc...what is my problem?
Hi, Make sure that you don't have any florescent tube lights near your TV. The light has some affect on TVs. Move the TV away form light.
Do you have anything connected to the tv other than cable. If problem persist call repairman and see what he has to say. Good luck.
Jul 20, 2011 | Samsung LN-S4095D 40 in. LCD HDTV
Can i repair a broken screen on a lcd tv?
LCD stands for Liquid Crystal Display. It is all one unit and when broken can not be repaired. The only way to fix it would be to purchase a replacement screen but that would probably cost more than replacing the whole TV. You might look for a used TV of the same model with a good screen and a bad circuit board and exchange parts but it is far easier to replace circuit boards than LCD screens so if you find a similiar model with a bad circuit board take the good board from your set to make the one with the good screen work again.
Sep 08, 2010 | Samsung LN-S4095D 40 in. LCD HDTV
Remote control will not work on Samsung 40" flat screen
I would try a universal remote just to see if it does it on a different one. You may have a defective remote. How long have you had this problem?
May 13, 2010 | Samsung LN-S4095D 40 in. LCD HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
How far away should a 40 inch tv be from viewer's sitting area?
whatever is comfortable lcd tvs do not put out radiation like plasma and crt (old) tvs did. so whatever is comfortable, plasma screen 6 feet minimum
May 08, 2008 | Samsung LN-S4095D 40 in. LCD HDTV
Picture appears to be cracked
It is cracked. Maybe not the first layer, but for sure the lcd is cracked. This is the reason why you found it on the garbage. The lcd panel is way more expansive like the tv itself. You can sell it on ebay for parts.
Dec 31, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Problem with 1080p via hdmi?
are you hooking up a 1080p source..if not then the set will not display the best picture in 1080p mode..
May 07, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Open Questions:
See all Samsung LN-S4095D 40 in. LCD HDTV Questions
Samsung LN-S4095D 40 in. LCD HDTV Logo
225 people viewed this question
Henry  Thomas
Henry Thomas
