im fixing a tv. Sony KV-G21MJ2. i've changed the regulator IC STRS6707 and it works. The next day i turned it on, the regulator ic get shorted, making the fuse to get open. tried to replace it again and it works. but the same thing is happening. today will work and tomorrow the ic will get shorted. i wonder why, could this be an issue of genuine parts? i've already change it 3 times now and still the same thing. need help pls.
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on. This arc will cause a "spike" which could possibly take out the regulator. Stargazer
Comments:
Feb 17, 2007
- If the set you're working on has a small driver transformer in the power supply, it may be your problem.
My Sharp 32" tube TV just goes off after several hours on. If I unplug it for a while and then...
(More)
My Sharp 32" tube TV just goes off after several hours on. If I unplug it for a while and then plug it back in, it will work for a while and then goes off. It is about 6 or 7 years old.
sharp 32f540 crt tv was playing fine, but just turned off. won't restart. it clicks when power...
(More)
SHARP 32f540 crt tv was playing fine, but just turned off. Won't restart. It clicks when power button is pushed and another click about a second later. What is likely problem? Worth fixing?
the tv won't hold certain stations, especially when starting cold and the tuner switches back to the...
(More)
the tv won't hold certain stations, especially when starting cold and the tuner switches back to the input space.
