Whirlpool top-loading washer problem
Our washer has a squeal when it is agitating and while draining. It's a gear-drive washing machine.
Thank you for any help you can provide.
  • suzpont Nov 28, 2008
    Thank you very much for your input. That's pretty much what my husband figured. Now to go find a pump!
    Thanks again!
    Sergeant:
    Champion:
  • 291 Answers
You will most likely have a bad pump / pump turns one way while agit and the the other dir in spin so pump runs when washer runs / i bet there is something in the pump / replace pump and you will be ok / larryyb
Posted on Nov 28, 2008
Will not agitate; agitator will not spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 20, 2010 | Whirlpool LXR9445JT Top Load Washer
Kenmore direct drive washing machine... there no
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Mar 30, 2010 | Kenmore Washing Machines
Whirlpool washer will agitate only, no drain or spin
99% probability that your timer switch is done. The only remedy is replacement.
Aug 23, 2017 | Whirlpool Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
My washing machine spins but does not aggitate what do i need to do?
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine does not agitate
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Agitator not agitating whirlpool quiet care 11 about 9 yrs old
Please see the Whirlpool installation and maintenance PDF on their Top Load, Direct Drive washers.
If this is the type of washer that you have, I'd pull the cabinet and check the Motor Coupler.
Following is a description of how to do it.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If it isn't the coupler, and you want to go further, it is possible that the "Agitate Gear" in the transmission is damaged.
Here is a description of how to "pull" the transmission on top load washers.
Although getting into the transmission is somewhat messy (it holds about 14 oz. of oil) it can be done, and replacing the gear isn't too difficult.
Oct 01, 2009 | Washing Machines
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
