Picture problem with Philips 17'' LCD TV, model 17PF8946/37
The L.H. half of the picture is intermittently unstable.  The TV often goes for several minutes without the problem, but then will go for several minutes with the L.H. portion of the screen flickering.  When it's happening, that part of the screen shows vertical bars consisting of the colors in the last stable image; it ''latches onto'' those color bars until the next stable image can be produced.  The behavior seems unrelated to how long the TV has been on or how well it has been warmed up.
  • 4 more comments
  • earlyreed Nov 30, 2008
    I assume the problem is somewhere in the main controller board, not the power supply board or the screen itself, but before I try to find a replacement board I want to know that for sure.
    It is model no. 17PF8946/37. (I had originally tried to include that information, but the model number wasn't recognized and was therefore changed to "generic.") I'm not sure whether the TV is under warranty, but I am considering a DIY solution in any case.
    I cannot find anything under "Menu" that says "Set up," nor can I find anything relating to "Reset all."  I've searched through the onscreen display as well as the manual.
  • earlyreed Dec 02, 2008
    Thank you for the suggestions. The first respondent (Benimur) was helpful in ascertaining that it was the main board, but his correspondence disappeared with the appearance of a message from a second respondent (who offered a suggestion that was not useful). I had, in fact, arranged to buy a board from ShopJimmy in the meantime, but it is great to have confirmation that that was a good idea.
  • earlyreed Dec 07, 2008
    Just to keep anyone who's interested apprised of the outcome (so far) regarding my Philips TV (if for no other reason than for its cautionary value):  I ordered the replacement motherboard, which seemed to me (and to others) the logical culprit.  Result:  no change in behavior.  (So I now have an extra motherboard, which probably is functioning just fine!)  The problem must be with the screen (LCD panel) itself; I had forgotten that there is a board resident in it that contains active electronics.  So, unless I find a source for a cheap replacement panel, it sounds as if I'm out of luck here.
    The problem is, incidentally, related to warming-up of the unit.  The L.H. half of the screen starts out completely black, then begins to flicker on with an image.  Partly warmed up the image is stable for a half hour or so, and then the flickering starts up with a vengeance (and doesn't stop).
  • earlyreed Dec 22, 2008
    Problem is now solved!  The cause is truly bizarre, and it has to do with a mistake in the original assembly.  When the cable connecting the motherboard to the panel was inserted into the socket of the panel a pin in the latter was bent, but in a way that still allowed contact with the wire.  The unit thus functioned normally (so that it passed QC, obviously) but was left with an intermittent problem that first showed up after more than a year of use.  Straightening the pin and reconnecting the cable solved the problem completely.  I guess the moral of the story is not to assume everything was assembled correctly at the factory!
  • 320 Answers
It is more likely that your problem is a panel or TCON board problem that a main controller (whatever that is) problem. When half the screen is involved, it is either the LCD panel OR the TCON board which addresses the panel that is at fault.
Posted on Dec 05, 2008
  • 10,594 Answers
Problem seems in main board of your Philips 17" LCD TV.
Required main board is available in Shop Jimmy on very low price approx $40
Good Luck.
Posted on Nov 30, 2008
    Genius:
  • 1,239 Answers
Hi Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 02, 2008
    they have a sensor on the front of the tv to measure ambient and adjust the tv brightness to the ambient light.
  • ABHISHEK.C
    OR
    Lines = bad circuitry. Could be a microchip. Could be a bad power supply to the microchip. Only a tech could look and tell.
  • ABHISHEK.C
    you might just have a problem with the inverter cicuit section of your LCD TV, bring it to he repair shope. cheer
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, as you posted possibly heat related. Could you post back the exact model pls? And would the unit be still under warranty or are you considering a DIY (do-it-yourself) repair?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 30, 2008
    Hi again,
    Appreciate the quick postback. Offhand, I would tend to agree with you:
    • power supply - doubtful otherwise you the unti will not power up at all or immediately revert to protection mode;
    • LCD panel/screen display - likewise doubtful, if so the problem would not be intermittent;
    • the above being the presumptions, then the the mainboard/controller would be the likely culprit.This could be verified by comparing voltage readings with known voltages referencing a schematic diagram.
    This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.
    Cheers.
  • Louie  Role
    Louie Role Dec 03, 2008
    Glad that my proposed probable fault confirmed the mainboard as the defective component.
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Apr 14, 2010 | Philips 17PF9945 17 in. LCD HDTV
MAGNAVOX 27" TV, PICTURE START UP PROBLEM
This problem with your television set is more than likely a problem with intermittent component failure. The fact that the television turn on for awhile is a sign the the component or components are intermittent.The reason the television turns off is that it goes into the protection mode caused by the intermittent component or components. They are unstable and are causing unstable voltages supplies to appear in the circuits. The television has a built in feedback circuit that will detect the faulty operation and turn off the television. When it stabilizes again the television turn back on. This is usually a sign of aging or faulty components. The problem will only get worse and the television should be thoroughly tested. You can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of your television and tell them about the problem you are having with intermittent turn on of the television. They will be able to tell you where to take the television for testing and service. I hope this information helps you with your problem.
May 19, 2009 | Philips Magnavox 27MS343S 27" TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Kv-36xbr450 picture freezes or wiggles
Check the cables going in and out of the tcon board if that doesn't fix it replace that board
Nov 25, 2017 | Sony KV-36XBR450 36" TV
Cannot view tv program while recording on VCR
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
