Question about Gigabyte GA-8N-SLI Motherboard
Will not display anything when booting up.
I'm sorry if this has been asked before, but I've been attempting to troubleshoot why I can't get anything to show up on my monitor. What happens is, I turn on the computer and all the fans start up (processor, video card, and system fans) so I know the thing is on, however I'm not getting any error code beeps, nor am I getting any visual feedback on my monitor. This is a new system that I have put together myself and thus it might be an assembly error, but I'm positive everthing is seated together correctly. My hardware specs are as follows Motherboard: Gigabyte GA-8N-SLI (not Pro, Royal or Quad Royal) Processor: Intel Core 2 Duo LGA 775 Socket RAM: Corsair XMS2 2GB of DDR2-SDRAM 800-MHz Video Card: PNY GeForce 8800 GTS OCZ Tech GameXstream 700W PowerSupply Western Digital 500GB internal SATA hard Drive Liteon DVD Burner LG 19" Flatron Slim LCD Monitor In all honesty, I'm not sure if it's the video card or motherboard (for the video card, Nvidia recommends having all the XP updates and the latest drivers before installation). Unfortunately, I need to somehow install XP before being able to do all that. Thanks to anyone and everyone who shares the solution on this one.
  • 2 more comments
  • Andrew Majewski Jan 15, 2007
    no, the monitor is connected to the video card.
    Heck, I tried both ports on the video card (the 8800GTS card as two monitor ports) to see if that did anything, but to no avail.
    no there's no onboard video for the motherboard I have, but I think it's time to give Gigabyte a call. Thanks for your help, nfandres.
  • Andrew Majewski Jan 22, 2007
    Actually, I figured out the problem and I feel like a complete fool for not having figured it out sooner. There was nothing wrong with the motherboard, as it works fine. What happened was that an incompatability issue with the processor and motherboard. Apparently, the Core 2 Duo is not supported by the GA-8N-SLI, even though it's dual core and a Socket 775 chip.
    Scholar:
  • 168 Answers
Does your motherboard has a builtin video card? u probably connected your monitor to it which supposed to be connected to your new installed video card.
Posted on Jan 15, 2007
  • Noel Andres
    Noel Andres Jan 15, 2007
    does ur motherboard has a builtin vga. did u try it there?(but be sure to remove the other card) if the problem persist, it means that your motherboard is the problem. coz vga is responsible for your visual display in your monitor. thats why whenever u bootup the memory of your vga is being display. have it changed. i beleive its still under warranty!
  • Noel Andres
    Noel Andres Jan 16, 2007
    Well, before u ring gigabyte try to change ur video card first. then if still the same, u can call gigabyte as u wish! ur welcome!
    Problem Solver:
  • 6 Answers
Looks like this is CPU issue, fin out more info about supported CPU on gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2173#anchor_os
Posted on Jun 30, 2009
I don't think your motherboard support core 2 duo
Posted on Jan 21, 2007
SOURCE:
Msi loptop no displays problem
Hi
I'm sorry but I could not find anything about this motherboard / machine. However most laptops have the facility to plug in a monitor via a VGA port on the machine. If doing this works then check settings on your computer to ensure that it is not set to only display on an external monitor. If it doesn't work, try booting your computer in "safe" mode (Press F8 during boot) if you can see anything either during boot or with ext monitor. If all these fail then probably the graphics section of your motherboard has probably failed and a new motherboard will be required to solve the problem unless the graphics card is separate (unusual in a laptop of this age).
Regards
Jul 15, 2014 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Can't do a system restore
Please contact acer and ask for operating system disk.
Jul 07, 2013 | Acer Aspire Computers & Internet
Dell p15s
Is it failing to show anything on the screen? Failing to boot?
Some basic troubleshooting steps:
1. If nothing comes up on the screen, first try removing your battery for a few minutes without the charger plugged in. Attempt to turn it on (it won't, but it'll discharge the capacitors). Then replace the battery and charger and try to boot.
2. Use the windows install disc to repair the operating system, simply insert it, boot from it (use F8 to select it if you need to) and hit repair when the window comes up.
3. Also, sometimes connecting to an external display (use the VGA port) can help troubleshoot whether it is a display, or a boot issue.
Jun 14, 2013 | Computers & Internet
I've a problem with my pc ProBook 4331s, when i switch on it does not display anything in a screen, please help me
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 20, 2013 | Computers & Internet
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
The laptop won't boot
probably the hard drive in your laptop is gone.
try booting ubuntu in live mode, so without installing it.
when the boot is completed, launch the tool gparted and see if it detects the hard drive: if it doesn't, you need to change the hard disk..
Jul 30, 2017 | Toshiba Satellite C655D-S5044 15.6" 2GB...
Problems : SMART Failure Predicted on Hard Disk 0 : TOSHIBA MK3265GSX-(S1) Model : DELL INSPIRON 14R (N4010) OS : WINDOW 7 Home Premium 1stly.. Sorry, Asking a FAQ that always or easy to find out in...
Very true a smart failure does not guarantee the hard drive will crash tomorrow or next year. However, with that said, I would opt to contact dell and have them replace the hard drive under your warranty. Like all things the computer and the components in it can and do fail. The reason for your warranty is if a bad part is received it can be replaced. I take care of about 20 servers and I have had this error on 2 of them (each server has 2 drives in it).
Anyway I would just save myself and future headaches and get dell to replace it now.
Altho this is not exactly what you asked for I hope it is helpfull no the less.
Jul 27, 2011 | Computers & Internet
My Gateway NV52 will not display anything on the screen. it stays black. The notebook powers up, but nothing is shown on the screen. How can i fix this?
First :
Try connect your laptop to other monitor ( crt or lcd ) if it looks normal on the monitor, it means your LCD laptop is broken.
Somestime often open-closed this LCD Laptop, may broken your Flexy data kabel of your LCD laptop.
Anyway Thx
Jun 23, 2011 | Gateway NV5215u Notebook
Gigabyte GA-8N-SLI Motherboard Logo
205 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
