Closed Captioning I cannot get the closed captioning to work on my Pioneer Elite plasma tv and marantz 5600 surround receiver. It used to work perfectly through the cable box, and after I set up my appletv, it quit. I can't get into the tuner setup on my television, so have been trying to find out how to do it on my receiver, without success. do you have any ideas? Thank you very much.
techman
  • 3130 Answers
SOURCE: Closed Captioning
you would open it in the plasma disply as it has to be on to work in one mode
Posted on Sep 08, 2006
techman
  • 3130 Answers
SOURCE: closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Posted on Aug 16, 2007
SOURCE: closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Posted on Sep 28, 2008
  • 126 Answers
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
Posted on May 18, 2009
smarthome2
  • 1114 Answers
SOURCE: Can't turn off closed captioning
CC is either active on the Cable Box or the TV, check your settings on both.
Posted on Jul 08, 2009
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
Have a toshiba 50" Plasma TV purchased 11/06.
I do not think there is an issue with the TV. I do not think that the station themselves broadcast the Closed Captioning.
Feb 04, 2011 | Toshiba 52HM95 52" HDTV Projection...
I have a pioneer VSX-1019AH-k receiver connected to a Samsung LED tv via HDMI. I am trying to use Closed Caption, but when I click on CC on the TV remote it says Not Available. Any help getting CC to work?
close captioning on a tv is usually only available for use when the antenna inputs are being used. it has no way to process a cc from an auxiliary source. you should have the capability of cc with a menu item in the cable or satellite box and with the subtitle command in your dvd. good luck
Feb 10, 2010 | Pioneer VSX-1019AHK A/V receiver
I can't get the tv to do closed captioning
Closed captioning on the TV will not work if you are connected to a cable box or satellite receiver. You will have to turn on closed captioning on the cable box instead - just go through the menu settings being sure the remote is set to cable and you should find it.
Oct 19, 2009 | Element Televison & Video
Cant get caption to highlight on setup menu
the closed captioning will only work when the tuner is selected. if you are using a hdmi input from a cable box you need to use the cable box's c.c.
May 01, 2009 | Samsung HP-T5044 50 in. Plasma TV
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Closed captioning
The closed captioning decoder circuit in your TV set may not be working, or the closed captioning information from the station may not be present. Start investigating by finding out if there is actualy closed caption from the station that you are tuned in to. If so, then call the tech support for your set to know if there is something that you missed in the set-up for the closed captioning. It may be very simple. If all of this does not work, then the closed captioning decoder in the set may not be working properly and require service.
Jerry G.
Jan 06, 2008 | Sanyo DP42746 42 in. Plasma Television
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Closed Captioning
Sep 08, 2006 | Yamaha RX-V1300 6.1 Channels Receiver
 Grubhead
Grubhead
