Question about Electrical Supplies
Honda generator em 1800
Generator is putting out only half of the power that it is suppose to
    President:
  • 1,388 Answers
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Posted on Nov 30, 2008
Regulator voltage generator honda EM 1900x
Type honda em 1900x owners manual into your computer search engine, it will bring up sites to get manual.
Apr 25, 2016 | Honda Electrical Supplies
Honda ems 4000 generator starts and runs great, but no power
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
May 13, 2010 | Cars & Trucks
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Mar 22, 2010 | Electrical Supplies
Honda 7000w generator outputs 6vAc when idling. When I rev it, power is then supplied. Why?
Well I dont know, but I do know that when it idles nothing is going to work. So whats the use of having a generator idle? Generators must turn at 1800 or 3600 rpm to operate.
Mar 13, 2010 | Honda Electrical Supplies
Generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Sep 25, 2009 | Honda Electrical Supplies
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Sep 09, 2009 | Honda Electrical Supplies
Honda EM 2500 Generator
Check out our testing video!
We hold parts too!
Oct 05, 2008 | Electrical Supplies
Electrical Supplies Logo
2,835 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
