Question about SanDisk Sansa c140 MP3 Player
Removal icon doesn't show on taskbar - SanDisk Sansa c140 MP3 Player
    Problem Solver:
  • 19 Answers
A removal icon is usually associated with a device mounted as a drive (an MSC device) because windows may delay/cache writes to it. If you're using a music player like Rhapsody or WMP to access the device (as an MTP device), it handles the transfers without buffering, so you don't need windows to unmount before disconnecting. The sandisk can be accessed either way (though there's an option in its menus to force it to be MSC).
Posted on Apr 28, 2009
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Aug 15, 2011 | Computers & Internet
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Jul 31, 2011 | HP Pavilion a1110n (PX743AA) PC Desktop
My acer doesn't have the cool windows 7 theme, like when you slide through the taskbar and the icons show a picture of whats going on in the page you're about to open, how do i change it to the...
Hi! Welcome to www.fixya.com.
You can download the taskbar theme from this website: http://www.topshareware.com/taskbar-themes/downloads/1.htm
Just pick your choice.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 18, 2011 | Acer Aspire 2930-4661 Notebook
I have a laptop satellite m305d-s4831& battery model PA 3634u-1BRS. My battery is not detect show in taskbar icon but battery icon is show red color in laptop and it is not work battery power, not...
Sounds like the cells inside of the battery went bad. Try another known good working battery, if the red X goes away on the battery then you know the original battery is bad. If the red x stays on the new battery then that means either your power adapter is bad, which you can try replacing that as well because it might not be putting out the correct voltages to charge the battery. If that doesn't work then the motherboard is bad for sure.
May 25, 2011 | Computers & Internet
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
Nov 22, 2010 | Microsoft Windows XP Professional
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
Lan Card Icon not showing in Taskbar
I think you need to reset the setting for showing on task bar, as in de-select the option, click ok, and then go back and select to show in task bar.
If this does not work, you system tray on the taskbar may be hiding some icons.
Mar 04, 2009 | Dell Inspiron 1100 Notebook
Pleomax problem
Try clicking on the icon in the taskbar and if it's like SanDisk flash drives there is a program you need to install from the Pleomax itself, that enables it and several tools as well. When you see that window, there will more than likely be an eject button as well.
Mar 16, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
SanDisk Sansa c140 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
