Question about Maytag PAV2300 Top Load Washer
Leaking from my MaytagPAV2300AWW
I have checked all - what else can it be? I think it's only when the washer spins out - it's leaking underneath and I can't pin point the location. I put paper under the machine - and it got wet toward the back right(looking at the front of the machine, then later Isaw it running out from the back left! I've checked w/ a mirror, flashlight - uncovered the back area where you can see the drain pump asembly - there is dust and no way it's been leaking there - that I can see. There is a thin tube I noticed in the back upper area (inside) that goes to nothing - what tube is that? very thin, small clasp onthe end. Did this possibly come loose? It doesn't have any drips or water running out of it though.I can see that the dust has been removed inan area at the back left and can't see up inside enough to find the source of my leak. Help? Any suggestions besides a repairman. What would be leaking inthat area? Thanks in advance.
    Problem Solver:
  • 6 Answers
Had this problem. In my case the leak was comming from the fill indicator tube. It is a small tube running from the side of the tub to the control panel. Air pressure built up in this tube activates a pressure sensor that will shut off the fill valve at different levels depending on the pressure. The tube had become dry and cracked at the joint where it met the tub. I didn't discover the source of the problem unitl the hose actually tore loose and the thing overflowed. Remove this tube and inspect it and I bet you will find a small crack or tear.
Posted on Feb 28, 2007
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Whirlpool LSQ9244EQO washer is leaking
IN FRONT? IF SO, PULL IT OUT AWAY FROM WALL 2 FEET AND LEAN BACK AGAINST WALL. LOOK UNDER MACHINE IN FRONT, PUMP HAS 2 HOSES ATTACHED. IF LEAKING THROUGH PUMP, REPLACE THE PUMP.
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LEAKY NON SPIN WASHER
sounds like you have a couple of problems, but the leaking is something you need to see where it's leaking from. as to the not spinning, it sounds like the transmission is bad
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Oct 03, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
