Question about Bosch Axxis WFL 2060 Front Load Washer
Maxx 2260 only works on 30 degrees rganks Sam
I fixed a y joint to the cold water outlet and fed ito both hot and cold on the machine
tks
Sam
Posted on Nov 29, 2008
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
Mar 26, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
Bosch maxx plus wfo 2260 will not spin it is working fine up until it is time for the spin cycle. Sometimes I have to stop the washer then just put it on to the spin cycle sometimes this works sometimes it...
Sounds like it is not rinsing properly.
If you have not already done so, then check the pump filter.
This is located at the bottom front right of basher behind drop down cover.
Unscrew anti-clockwise to remove and clean.
Mar 25, 2010 | Bosch Washing Machines
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
My bosch maxx wfl 245s washing machine will not work at any setting other than 30 degrees quickwash.
Make sure both hot and cold water are turned on. If that is ok you may have a faulty control board.
Apr 28, 2008 | Washing Machines
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
220 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
