Question about Maxtor Hard Drive
Jumpers I need to know where my jumper goes on my maxtor 87000ab to make it the master drive
  • Anonymous Dec 07, 2008
    What is the master jumper
    Sergeant:
  • 236 Answers
There should be a diagram on your drive that shows jumper locations.
Posted on Dec 05, 2008
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
I need the jumper positions f9or the maxtor 256
I'd need a better model number, however the general jumper for most maxtor drives is J50 on = master, off = slave or cable select.
/j50 is usually closest to the data cable and the jumper goes on vertically.
Feb 25, 2011 | Maxtor Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
What are the jumper pins on my Maxtor 6l200m0 and 6l200s0 sata drives for?
To control how the computer separates and assigns the drive's working order and placement.
The most basic positions are:
Master - By default the motherboard will boot to this drive first, therefore it's the "master"
Slave- What it sounds like. It's under the "Master" and isn't booted by default.
Cable Select (CS) - What it sounds like as well. The cable that goes from the motherboard to the hard drives. There are TWO positions at which the cable connects to the drives based on their placement. That placement determines which drive is master and which is slave. The advantage of this mode is it's ease of use. (Use only when you've got two hard drives)
That's the basics of the basics. There is A LOT more to those jumpers...but you won't ever need to know what so don't ask ;)
Let me know if you have any other questions.
Nov 22, 2009 | Maxtor Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper setting
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Jan 23, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Maxtor hard drive model 54098h8 where do I put jumper for main drive
on the model 54098h8 this is a IDE drive and was in service in the mid 2000 era. most drives warranty expired by 2003.
the jumper postion is for J50 which is MASTER with jumper ON and SLAVE OFF See photo below or look on this link
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/d540x-4k_guide.pdf
All material contained herein Copyright © 1999 Maxtor Corporation.Contents and specifications subject to change ®
without notice.DiamondMax™, MaxBlast™ Plus and MaxFax™ are trademarks of Maxtor
this is a photo of the master from the PDF
May 07, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
51 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
