Question about Samsung SyncMaster 931B 19" LCD Monitor
Blue power LED flickers on and off; monitor won't turn on
This happens periodically when we reboot the system. The display flickers on for a split second then goes black and the power LED begins flashing. Usually, the problem is fixed if you turn it on and off several times but this time, it isn't working. What had the same problem with an LCD from another manufacturer (Gateway) and it never did come back on. We need to know ASAP because we rely on our computers for our home business. We've ruled out problems with the video card and operating system (Windows 2000 Advanced Server), so it has to be the monitor.
  • 1 more comment
  • bargainbuysa Dec 07, 2008
    I have the same problem.. When you power on the unit the power light just flickers and the monitor stays black. I tried a different power cord, reboot etc. I also have a Samsung 931B. Manufactured in April 2006.
    Any suggestions? Is it still covered under any warranty? the serial number is ME19H9NL4166455 R
    THANKS
  • jason84109 Dec 15, 2008
    I have the same problem with black screen and flickering light. Nothing works. I guess they are just crappy monitors.
  • rob2748 Apr 13, 2009
    blue led on/off flilckers. started intermittenly then increase, now will not power up, black screen
Yup, my monitor had similar symptoms. Replaced 3 bulging caps on the power board and now it is perfect.
Posted on Apr 03, 2009
  • 3 Answers
I have had the same problem with two of these monitors. If it is not still covered under warranty, start by opening the case. Once you remove the power board, you will probably notice several capacitors (the round, can shaped parts) that have tops that are not flat. If you see any that have bubbled tops instead of being completely flat, they need replaced. Once they are replaced, the monitor should turn right back on. Hope this helps.
Posted on Feb 20, 2009
Call 1800 samsung and it s cover under warranty untill may 2009 and thye will send a replacment free to you 7-14 days toa ups store near you all you do is walk in and exchange it
Posted on Dec 18, 2008
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Blue led problem in alesis mk1 active
I dont think its anything to worry about, if the unit didnt turn on at all or the LED flickered then you would need a capacitor or 2 changing; check here; http://www.neufeld.newton.ks.us/electronics/?p=232
Apr 18, 2009 | Alesis M1-Active-MK2 Powered Studio...
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Monitor does not come on
Knowledge Base
The above link is to the Dell Knowledge Base and specifically to monitor problems. There are links on the page to "blank screen" or "no video." But that may not be descriptive of your problem. It has not been indicated whether any power led on the monitor is lit. What happens if you "turn off" the monitor and turn it back on? It is possible you simply have a loose cable or the power cord might be bad.
monitor wont turn on
Feb 14, 2018 | Dell M570 15" CRT Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
274 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
