Question about Fuji FinePix S9500 Zoom Digital Camera
Command dial The command dial has fallen out. It doesn't appear to be broken, but won't engage when re-inserted.
2 Suggested Answers
SOURCE: is there a repair for command dial on a fuji s9500
Yes. contact Fuji and it cost about £14.00, its a doddle to fit.
When you recieve it you'll work out how to remove the broken part because you'll understand how it locates, basically a small Pozi screwdriver and a sharp knife to lever the top off.
Posted on Feb 02, 2010
Murray 42" tractor drive won't engage
Does the wheel you took off only have one centre nut?
If so it whould appear that you may not have put the key in the keyway of the shaft and the wheel when you put it back on. Maybe the key was in the wheel and hs fallen out at the repairers.
Sep 28, 2017 | Garden
The control dial on my GE washer doesn't engage and let me dial a setting.
Is this washer new if so should be covered by warranty if not attempt to take top off the way that dials turning it looks like it aint making connection at back of fascia may have popped out at back of dial knob
Apr 01, 2013 | Washing Machines
Front passenger seatbelt on a 2005 volkswagen passat won't engage on the receptacle
remove it and bang it while it upside down something might have fallen into it like change
Oct 10, 2012 | 2005 Volkswagen Passat Sedan
My serger won't cut
Sounds like your blades are either dull, misaligned, disengaged or broken. Examine your serger book for how to re-engage the blades. If they are engaged, make sure they are aligned correctly. If that still doesn't help check for damage.
Sep 10, 2012 | Brother 925D Serger
Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
May 05, 2012 | John Deere Garden
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Fuji FinePix S9500 Zoom Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
