Fan comes on butno heat - Heating & Cooling
  • Anonymous Dec 26, 2008
    My Friedrich Wallmastrer PH15 fan comes on, however it does not produce any heat?
  • 27 Answers
You prbably have a dirty filter and the unit has gone off on "high Limit". this means that since there was not enought air coming back through unit (due to dirty filter), it overheated and a saftey device called a "high Limit" shut it down. One of the signs that the high limit has tripped is the blower comes on to cool the unit down but the burners will not come on. Some high limits reset themselves when they cool down but it is safer to call a pro.
good luck
Posted on Nov 28, 2008
  • 306 Answers
Sounds like you have a hot surface ignitor that has gone out. Go down to the unit remove top cover to inspect the operation of unit. First stage is draft fan it should come on and clear out the flue about 2 min. later the hot surface ignitor starts to glow it sits right in front of the burners if no glow the ignitor needs to be replaced. let me know how it turns out. Ken
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
The microwave lights up;the numbers start counting down butno fan itdoesn turn on to cook
time for a new microwave same thing happened to mine searched for the part number and price. the price for the part was more than the actual microwave.
Jan 04, 2015 | Cars & Trucks
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Can't hear my caller .Iget video butno voice
from the main screen goto Options/tools/sound settings
or
uncheck the mute button from the controls on the bottom of the call screen
Feb 24, 2012 | SKYPE Computers & Internet
Is the heating coil on my furnace supposed to come on before the fan or visa-versa?
Heating coil comes on first. When heat gets to a specific level, fan comes on. Fan stays on after coil is de-energized until heat drops back to that same specific temperature.
Charlie
Feb 20, 2011 | Intertherm Heating & Cooling
Our fan has been on continuously for 2 years. Now the remote doesn't work. I have changed the batteries; butno success. Any ideas
there are microswitches behind battery and in fan need to make sure they are set the same. hope this helps
Dec 25, 2010 | Hampton Bay Dryers
Fan come on no heat come out
well you need to establish heat source is coming on so fan can take heat if heat source coming on you may have a blocked heat exchanger get it serviced an problem should be fixed, if heat sourc not coming on you definatly need service agent
Nov 22, 2010 | Heating & Cooling
My dryer only dry for 10 minutes
SOUNDS LIKE YOUR COILS ARE BAD
Jan 24, 2010 | Roper RGS7646KQ Gas Dryer
Soon as i turn on my heat my cooling fans come on first
It sounds like you do need a thermostat with your heat shut off and the gauge will raise a little then the car doesn't have that heat drawn from it indicating that you most likely do need a thermostat. As far as the fans coming on immediatly that could be a different problem it is most likely the coolant temperature sensor that tells the fan's when to come on. If this sensor says the coolant is hot the fans will come on immediatly. These are seperate problems as the coolant temperature sensor does not have anything to do with the cabin heating system. You should first check the level of your coolant is full, This could also cause your cabin heating system to perform poorly, and may have adverse effects to the engine cooling system. (fans)
Dec 31, 2009 | 1995 Nissan Maxima
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
