Question about GE (PSS26MSRSS) Side by Side Refrigerator
My subzero fridge no longer seems to be cooling, its only 4 years old. Ive checked all the obvious stuff, do u have any suggestions?
    Sergeant:
    Champion:
  • 311 Answers
Is unit running? Need to know if condenser fan (by compressor), ref fan, and compressor (the one on the right if this is a ref/frzr unit) are running.
Posted on Nov 28, 2008
How do I turn off and reset side-by-side Subzero fridge, to vacuum condenser?
Usually vacuum condenser light is on, not because of condenser coils dirty, but low on refrigerant unit, so compressor is running longer then usually. You can shut your subzero off at breaker box, if light will keep coming on in day or two, you will need to call service to replace evaporator. Most likely evaporator in Fresh food section has leak(at list its most common place). Check this video I made, even if Your Sub Zero sideXside it still will look the same about changing evaporator. Hope that was helpful.
Feb 20, 2015 | Sub-Zero Refrigerators
Frig is about 20 years old been working good. now the refrigrator side is not cooling like it should.ive cleaned the bottom coils and around the compressor area at back. seems to be some ice accumulation...
Hey sounds like thermostat is no longer working (isn't regulating fridge's temperature), you can replace it yourself, all you need if fridge make and model number and order one from an appliance repair shop. Or have them do it. Either way it will probably cost more than the fridge is worth ($50 average for thermostat) to get it fixed...
May 22, 2011 | GE Refrigerators
Hello. My freezer part of my subzero 690 is getting too cold. The temperature has dropped to -8. My normal setting is zero. I tried raising the setting to +5 with no effect. I tried turning the whole...
check u tube for problem solving videos.
There are a number of great troubleshooting u tube videos, which show you what to look for and many of the fixes are really simple and are universal for all fridges. The simplest is that you left a door open, moisture got in and froze causing ice to build up, so you have to thaw it totally, not just turn it off. I moved my older subzero and think one of the tubes must have been knocked and it lost its Freon, so stopped cooling. The cost of having it recharged was so prohibitive (ie environmental disposal issue meant it had to be moved to a special location fixed and moved back at my expense or Subzero said it was a closed unit and you had to replace the whole thing$ 1,300 for the condenser alone) so, I tossed it + bought another used one until my renovation was done.
Generally with any fridge, there seems to be 2 possible Simple reasons:
1. DEFROST MODE PROBLEM it is stuck in defrost mode
. a)the defrosting tube is plugged
b)The tube or thermostat is frozen, most likely because someone left the door open or the seal is poor;
c) termostat defective-untube video explained how to test circuit;
4. CONDENSER ISSUES: the condenser coolant gas is low and can be easily recharged- see the u tube how to video;
5. Condenser is dirty and cannot breathe- vacuum it;
6. The condenser overheated and needs replacing . 4-6 will have the condenser blowing cool not warm air.
I have had this problem with the fridge portion of my SUBZERO bottom freezer and Subzero (and a repair person ) gave me some good advice, which should also apply to yours, but you might want to call them yourself:
1. Simplest fix- if the defrost tube is blocked or frozen, the defrost cycle will stick on preventing cooling (either freezing up or heating for the defrost cycle not cooling); Some subzero models are especially prone to this. I could see part of my tube inside the fridge on the back wall close to the bottom where it drains and removed the panels to expose and clean it;
2. You should pull it out and unplug it to get it to defrost fully. After doing that once, I made sure my fridge was on a separate circuit or switched!! Yours might not be the same, but on mine the tubes run through the fridge to get to the freezer so both parts have to defrost;
3. Subzero fridge and freezer each have their own independent condensers, so you might be hearing the condenser for the fridge running, even though one part is turned off.
4. Check the thermostat to see if it is working. There is a good u tube video on this.
5 Some of the u tube videos show how to "recharge" the Freon. Subzero told me these are sealed units and could not be done, so regardless of the problem, the condenser had to be replaced. The subzero repair person was really helpful + checked the Freon or gas level (Mine was old enough that it was Freon not the newer environmental stuff) so they would have to haul it away to drain and recharge it + then the condenser might still have to be replaced.
Good luck
Joan
Jan 15, 2011 | Sub-Zero 690 Side by Side Refrigerator
Hello. My fridge freezer is playing up. It's from John Lewis and is about 4 years old. The fridge was not reaching the right temperature and it was making a funny noise, so took it apart and found that...
most fridge-freezers send cold air from the freezer to cool the fridge. the flow is usually controlled by adjusting a 'warmer-cooler bar or wheel in the fridge. maybe you disturbed its original position while working on the fan.
Jun 19, 2017 | Refrigerators
I have an Caloric GFS207- 1L 01. before the winter came i had to turn down the freezer one number because it was to cold. now my problem is in my fresh food top self next to the box thing(damper maybe?)...
Yes - there is a cold air damper.
This regulates the cool air flow from the freezer to keep the fridge cool.
If there is condensation - i would suggest checking the door seal for warpage, tears or other abnormalities allowing hunid room air into the fridge.
Thanks
Feb 16, 2010 | Refrigerators
Have a subzero set - fridge and freezer. The
First, check the compressor fan. Make sure it is turning. If this fan is not working properly, the refrigerant will be be cooled adequately. This lowers the efficiency of the refrigerator and causes it to run more.
The fan is probably located in the back of the bottom of the refrigerator. It pulls air across the coils and blows the heat out the back of the unit.
If the fan is not turning, the fan motor will need to be replaced.
Oct 14, 2009 | Freezers
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
My LG LRBN20514ST Fridge is not cooling
Set the temperature to low in the fridge and reply what happens.
Also reply if items in the freezer are frozen hard.
Jan 24, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
