Question about Maytag Atlantis MAV9501E Top Load Washer
Spins only with manually start /spin sounds like jet engine
Maytag Atlantis Washer Model # MAV9501EWW In spin cycle I half to manually start it. When spinning it sounds like a jet engine (also like a dry bearing. I can stop the tub by hand and the jet engine like noise (also dry bearing like sound) stops.
I suspect a dry bearing but I need to know if threads on plastic nut between inner and outer tubs are left or right hand threads. If I remove this plastic nut will it give me access to the bearing?
How much does the bearing cost and do I need a puller to remove it?
  • Dwatex1969 Nov 29, 2008
    Thank you for your insite but I have gone ahead and took it apart. I caught it before the shaft was scored. There was some miner surface rust but it cleaned up well with fine emory cloth. I'm now installing the new bearing after pressing as much high temp grease into the bearing as possible (this was not easy).
    I grew up an Auto Mehanic along with 16 yrs experience in Electronics so I am not afraid to try.
    Dwatex1969
    Sergeant:
    Champion:
  • 311 Answers
Throw this machine out; it is a piece of junk. Transmission shaft is probably scored up so new bearings will do you no good. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Model MAV9501EWW not spinning but it is pumping
Hello & Welcome to FixYa
When the washer is not spinning however, pump out the water then the problem is with the lid switch that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 13, 2011 | Maytag Atlantis MAV9501E Top Load Washer
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
CLOTHES STILL SOAKED AFTER SPIN CYCLE
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
Jan 19, 2008 | Maytag Atlantis MAV9501E Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV9501E Top Load Washer Logo
423 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
