Question about OKI C3400n Laser Printer
Grinding noise on OKI C3300
I have changed the toners, and the yellow one was causing problems, at that time all was well, The yellow was replaced immediately and after replacing this the printer now makes a terrible grinding noise. I have had this printer a year at the end of December 09
  • theflickster Jan 07, 2009
    I have the same problem - if you figure out what is wrong let me know please. Also, when my pages print it looks like there is light gray toner over the whole page... very faint, but noticeable. Any ideas on that one as well?
I have had a similar problem. . Black drum needed changing. There was also a grinding noise developing. I have taken each drum and toner module out of the printer and booted it up with one of the 4 missing. It was the Cyan drum that was making the noise. . Question is what can I do? I am not a printer expert. .
I will contact the local printing shop that I use for more info and will come back to you. I suspect that I will need a new drum . . .
Nick Smith
nick@selectaccountingservices.co.uk
Posted on Nov 01, 2009
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Error code taskalfa 500ci , c3300
C3300, AGC Error. something in the copy lamp or optical section
Jul 08, 2014 | Kyocera Task Alpha 400ci / 500ci Yellow...
Oki c3300
there is pickup roller for picking up paper see that clene it and replace it if needed.
Jun 07, 2012 | OKI C Office Equipment & Supplies
Oki c3300 amber light blinking
how to reapir samsung c3300 lcd light
Jan 26, 2011 | OKI C3400n Laser Printer
Oki C3300 toner replace, where do I stick the new chip
On the top left hand side of the cartridge, usually where the letter representing the colour of the toner (in your case M for Magenta) appears, there is a small removable section, about 15mm by 20 mm in size. Prise this open with your finger nail or small screwdriver. Remove the old chip and insert the new one in here.
Jul 30, 2009 | OKI C5200n Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Oki C5500 printing a yellow stripe
1) clean LED heads with Alcohol swab.
2) Check fuser rollers for dirt, smudges. Clean with swab.
3) Remove all toners/drums and check for spilled toner. Vacuum or wipe clean.
4) Check tansfer belt for marks, stray toner, creases.
4) Re-seat toner and drum cartridges.
Nov 23, 2008 | OKI C5200n Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
OKI C7300
Reload the yellow toner and re-seat the drum assy
check for foreign objects under toner/drum assy
make sure toner is locked and drum is seated correctly
also, check the small door on the left side of drum
if stuck closed, gently push open with small screwdriver
Mar 03, 2008 | OKI C5300n Led Printer
OKI C3400n Laser Printer Logo
1,005 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
