Question about Sony 46IN TV Stand Designed for Model KP-46WT520
Sony picture My SONY has a piictue that is off on the perimeter. It looks as if the projection is off, or the prizsm is moved. Maybe one of the projections are off?????
  • ffunderscore Dec 29, 2008
    the picture is off like the prizm has been moved I know how to adjust the color lenses but the picture is curved like your watching it on a drinking glass
  • 81 Answers
Can U explain this problem a little more in detail. Are the colors off ? is the picture over to 1 side? I am not following your description.
Posted on Apr 06, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Sony HDTV S-Master SRS
Looks like dust on the curves of your blue lens, maybe the mirror. Did you just do a move, repair or cleaning?
It's time to clean, it will look great when your done! I'm sure there's instructins out there.
May 19, 2013 | Televison & Video
Sony KP-65WS510 Convergence Problem
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 17, 2009 | Sony KP-65WS510 65" Rear Projection...
3d picture
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Jean
Dec 28, 2008 | Sony KP-43HT20 43" Rear Projection...
I tested all six pico fuses (3.5 A) and all tested fine on the continuity test. Is there something else I could check?
Dec 05, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-53S75 blue convergence problem...
what about settings cool med warm ? did sumone chage those
Jan 18, 2008 | Sony KP-53S75 53" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP53HS30 projection tv looks 3 d
You have a convergence problem, was it moved lately? Did you try the convergence setting in the customer menu?
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Color distortion issues
Oct 07, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
55 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
