Question about Dell Inspiron 1501 Notebook
My dell inspiron 1501 wont connect wireless. I can only connect using ethernet cable. It has previously connected wireless for the past year. Please help?
  • 3 Answers
Go to the dell website, look for the support section. Download the wireless drivers for your laptop and install.
Posted on Nov 29, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
My Dell B130 Inspiron won't connect to my landline. The wireless connection works fine but when I plug it into the landline, it doesn't connect. When I check the network connections, the local line reads...
Do you have the correct log in details?
To see if your ethernet connector is functioning, connect from one of the 4 ports behind your router directly to PC ethernet, this way you don't need log in details. If this works, then you need log im details to connect directly.
Jan 05, 2018 | Dell Inspiron 1501 Notebook
My Dell 1501 laptop wont detect any wireless network and will not pick up my network even when using an ethernet cable to the router.
Hi, you need to check that the drivers are installed working properly with no problems. Go to start, control panel, hard ware and select device manager. Any problems will be highlighted with a yellow ?. right click here and select update driver. If this doesn't work go to Del's website and download the latest driver. Hope this helps
Jul 12, 2010 | Dell Inspiron 1501 Notebook
Dell inspiron will not connect to any internet
Sounds like perhaps you have a winsock error.
Hope that helps you. Just FYI, a corrupted WINSOCK issue is usually the result of a virus or spyware corruption.
Oct 26, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 3800 laptop SSID ?
SSID: Service Set Identifier
It is the name of the Wireless connection,
Seems ur trying to connect to internet using WIFI and not a cable.
Then in this case u need to set up ur wireless connection
Check this link to connect to wireless
May 30, 2009 | Dell Inspiron 1501 Notebook
How do you connect to the internet ?
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Connecting a cpi to the internet ?
1) You can use a PCMCIA card (for example a Dell Fast Ethernet 10/100 Base-TX by 3Com) with a 'dongle' to connect to the ethernet cable via an existing card slot on the left side.
2) You can get a docking station set-up (i.e. Latitude 'C/Dock') which comes with the ethernet cable connection. ...pretty affordable used on the 'net.
3) If you has a wireless router you could hook a wireless USB adapter tp connect wireless to yout router.
Dec 28, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Nov 28, 2008 | Dell Inspiron 1501 Notebook
No wireless connection because of problems with my Base System Driver and SM Bus Controllers
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column. If they are alerts, you need to go to and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the 1501 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 05, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
140 people viewed this question
Alun Cox
