Question about Polaroid FLM-323B Television
Tv taking long time to come and when come on making humming noise
When i turn takes about 15 min.to come on and when the picture starts coming in it makes a constant humming noise
Totally worked! Thank you!
Posted on Feb 27, 2009
Worked like a treat nice one
Posted on Feb 12, 2009
  • 3 Answers
. These are the caps I replaced they where only a little swollen I was worried if they where even the problem but I changed these three and was very happy that my TV is now working like new again the two top ones I replaced with 1000uf 16v the lower one is 1000uf 35v ok well I hope this helps ya
Posted on Dec 02, 2008
My television has no picture for aprox 15 mins but has sound
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 05, 2014 | Televison & Video
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
My samsung 42inch tv has started to play up when turning it on
Sounds like they may be an issue with the startup circuity
probably a start-up ic that controls the boot relay....you need to get it looked at by a tech or if it's under warranty take it back..
hope this helps,ben
Aug 13, 2009 | Televison & Video
Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Jun 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
I have a 37" Polaroid tv. About 2 months ago when turning on the tv there would be a humming noise for about 15 mins, now the tv won't come on at all. I've trie d replacing the fuse but it continues to...
The humming noise is produce when the power supply is trying to compensate the other circuitry's demand for proper power getting to them. The problem is that the capacitors have lost their dielectric capabilities and are not able to filter and provide a clean power in a timely manner.
Let me know if you require further assistance.
Dec 12, 2008 | Polaroid FLM-2601 Television
Polaroid FLM-323B Television Logo
197 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
