Sceptre 42" LCD flat screen TV. The input ports have been gradually going out, so it's getting harder and harder to find working ways to connect DVD players and other devices to it.
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
SOURCE: Question regarding audio connections Akai 30" LCD TV
How to connect External Speakers (with Amplifier) or Headphones to Akai LCD 32LW7?
SOURCE: Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Please dont forget to vote if you liked my answer
thanks
