Question about Mission MS752F Speaker
Mission 752F blown driver
Where can I get a replacement for the blown driver (woofer)??
I got a quote form one source and it was very expensive, around $200.
Part number LF-AE625.
Thank you,
Roman.
  • romsan Nov 28, 2008
    Thank you,
    The price I got was from Canadian retailer which is servicing Mission speakers. I just think that the price is a bit too much for just one driver.
  • 4 Answers
Go to Mission directly; one of my speaker cable terminals was broken by accident on my 733i floorstanders and they sent out a replacement within a week. Excellent service. They have a contact email and will get back to you pretty quickly with an answer.
Try Ebay second!
Posted on Dec 04, 2008
  • 333 Answers
I would try ebay first. If not follow this link to see if they can help you out. Mission ltd is located in the uk. http://www.mission.co.uk/
Posted on Nov 28, 2008
  • Frank Russo Nov 28, 2008
    I would try ebay first. If not follow this link to see if they can help you out. Mission ltd is located in the uk. http://www.mission.co.uk/v
    Disreguard the link ending in v I made a mistake.
    Thamks
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Mission m73 with a woofer which seems to have gone dead
I use to have some warfdales that did that, and generally it was the cross over unit that would blow a fuse, if fitted.
Dec 26, 2013 | Audio Players & Recorders
Speaker suddenly emits very loud noise. Have to unplug it.
Bad capacitor(s). Happened to mine too. Opened it up to find 2 completely blown apart, and 1 bulging. Relatively cheap and easy to replace.
Jan 22, 2013 | Mission 70ASA Speaker
Woofer sound distorted
What audio source you put into your Amp? you can lower the source volume also the amp volume to confirm, where the problem come.
Source input is also important whether you using low level or hi level input.
Nov 18, 2012 | Acoustic Research P315 HO Speaker
Replacement base soeaker for mission 782
I have the same problem too, can anyone know where we can get a replacement of the woofer?
May 11, 2009 | Mission 782 Main / Stereo Speaker
Need to Replace the drivers on Mission 782 speakers.
Unless the company that made the speakers machined the allen screws themselfs, I'm sure any standard or metric allen set will work. Just becareful of the bracket because it may be glued to the speaker frame or there might be a gasket between the 2.
There will be a some wires coming from the crossover that will lead to the tweeters and to the woofer. They are terminated with female connectors that will slide on to the male end on the speakers. If the speakers that you are getting are from the same manufacture, then they should have the same fittings. If not, you may have to replace the females to match. It's a simple strip and crimp process.
Just make sure to mark the wires so you know which one is pos and neg. If you mix them it will throw your speakers out of phase and they won't sound right.
Hope this helps.
Mar 24, 2009 | Mission 782 Main / Stereo Speaker
Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Aug 20, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Mar 18, 2007 | Mission 702 Speaker
No Woof
If these are Mission 780s your talking about, you're not the only one. The woofers supplied with the speakers originally have a known design/manufacturing flaw causing them to go "open circuit" after a few years use. The good news is that IAG (who now own Mission) can supply you with a pair of replacements for about £45 plus postage. (You'd be forgiven for thinking they should supply the replacements for free given the cost of these speakers new and the fact this is a design/manufacturing fault). Replacing your woofers is easy. Take off the front baffle. Remove the four rubber plugs that the baffle attaches too, and take out the 4 screws you'll find behind them. Now ease off the plastic moulded front pannel. Remove the four screws holding the woofer in place. Pull the spade connectors from their tags on the back of the speaker. Put the new woofer in by following this proceedure in reverse.
Aug 03, 2006 | Mission 780 Main / Stereo Speaker
Mission MS752F Speaker Logo
414 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
