Question about HP DeskJet 920c InkJet Printer
Purchased HP*Deskhet F4235, can't get color cartridge to lock in
To space. Got Black in and locked in place but can't get the color one to lock in. Also can this unit be used alone without havng it connected to a computer
    Scholar:
  • 69 Answers
for better solution with graphical representation click on the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01367400&lc=en&dlc=en&cc=us&lang=en&rule=29038&product=3571316
And the solution for your next question is that the unit can be used with out connecting to computer for making only photocopies. you will not be able to print,scan with out connecting it to computer.
Posted on Nov 28, 2008
Ink cartridge will not lock into place
Hi Cynthia..are the taps broken on the carriage where the cartridge goes...???? color one on the left and black on the right.
Is that model right......a "J4650"
Apr 13, 2014 | HP OfficeJet Office Equipment & Supplies
Door closes with no cartridges but will not with cartridges. looks fine, worked fine before putting in new cartridges for the 1st time. hp color lasorjet 3600n
Did you make sure the cartridges clicks in place? There are while plastic locks on each cartridge and hopefully they are not broken. Not expensive to purchase but major teardown to replace.
Oct 23, 2013 | HP LaserJet 3600n Printer
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
Carriage gets stuck, Won't print. Power button starts flashing "red"
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 09, 2010 | HP Photosmart 7450 InkJet Printer
How do you replace the ink cartride in a hp 2175 all in one printer
1. Prepare the replacement cartridge by pressing down and back on the top of the protective plastic, then sliding the cartridge out.
2. Set both the cartridge and empty cartridge protector aside.
3. Turn on your printer and lift the access door until it locks into place. The print carriage will move to the center.
4. Once the print carriage has stopped moving, raise the latch to release the empty cartridge. 5. Remove the empty cartridge by pulling towards you. If you are replacing the tri-color cartridge and need to remove the black ink cartridge temporarily, use the empty cartridge protector to hold it. 6. Hold the replacement cartridge by the sides and remove the black plastic tape. 7. Insert the replacement cartridge into the appropriate slot (left for tri-color, right for black) until it snaps into place. 8. Pull the cartridge latch towards you and press down until it snaps into place. 9. Close the access door. -------
You may also download and refer to it's product manual :-
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
and
http://h10032.www1.hp.com/ctg/Manual/bpu73554.pdf
Sep 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
White line along right side with black ink only
One of our IT guys came out and said he had figured out the solution on another printer with the exact problem. The problem is that the ink cartridge is not in tightly enough. It LOOKS like it is; the lock is even shut and the drum rolls smoothly. BUT, there is a tiny, and I mean tiny, bit of space between the cartridge and the drum, thus the ink gap. So, the solution is to be sure the cartridge is pushed back into position very tightly. We had been tentative in shoving the cartridge in because of the plastic pieces, but the lock locked just fine and we heard a slight clicking sound. Now we know to put it in carefully, then push hard into place. Problem solved.
Jan 07, 2010 | Dell 3100cn Laser Printer
F4235 cartridge will not fit in slot
Hello.
Be certain that you are using the HP 60 (CD947FN) Black/Tricolor Ink Cartridge.
If you have the correct cartridge, it should fit and just snap into place.
Hope this helps.
Nov 13, 2009 | HP DeskJet 920c InkJet Printer
Problem with ink cartridge
There is something broke with the piece that keeps it in place. You need to take it out and look real close to how it works. Look at how the color works and compare the two.
Sep 23, 2006 | HP PSC 1610v All-in-One Printer
HP DeskJet 920c InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
